I've seen some Xvid torrents which are progressive NTSC or PAL yet the frame rate is still 29.97 or 25 fps and the frame rate is smooth. How can this be done with Avisynth as I thought if you convert interlaced to progressive then you'll get a choppy frame rate unless you double the FPS. I don't want to double the FPS because then my video won't be Bluray compliant.
You can't. A true 30i source (typically live sports, news) converted to 30p won't look too bad but it will flicker during bright high motion sequences and will be noticeably less smooth than converting to 60p. Compare the 30p and 60p rows in the first video (24v30v60.avi) in this post (watch it full screen for greatest effect):
http://forum.videohelp.com/threads/3...=1#post1888926
If you blend the two fields together it will flicker a little less but you will get fuzzy or double-exposure frames.
A film source will have several little jerks every second because every 5th frame will be a duplicate. Or if you blend the two fields together you will get an annoying phasing effect during motion because two of every five frames is fuzzy.
How to fix poor Interlaced to Progressive Conversion with Avisynth?
By VideoFanatic in forum RestorationReplies: 7Last Post: 2nd Oct 2012, 16:15 -
interlaced and progressive in same video. how to make only progressive.
By OmniShadow in forum Newbie / General discussionsReplies: 32Last Post: 18th Sep 2012, 23:44 -
slow motion by interlaced to progressive conversion?
By menczel in forum Video ConversionReplies: 9Last Post: 24th Apr 2011, 10:39 -
Conversion to Progressive Scan from Interlaced DV. Necessary?
By DeXeSs in forum Video ConversionReplies: 3Last Post: 13th Nov 2008, 14:34 -
Converting 30fps Progressive to 25fps interlaced ? (Avisynth & VDub)
By blewyn in forum Video ConversionReplies: 6Last Post: 12th Jun 2008, 17:51
