    Hey there!
    Using Firefox, trying to find a program or means to rip videos from logotv.com (mainly RuPaul's Drag Race and the extra scenes that are only available from their site). I've tried Orbit, DownloadHelper, GetFLV and a lot of other similar programs but nothing seems to detect the video; most of these programs will detect and download the ad that plays immediately before the episode, but nothing else.
    Help? Pretty please? I'll answer any questions I can to narrow down the possible solutions.
    RTMP Explorer appears to work. On the one video I tried it downloaded in four pieces though.
    No worries, so long as they're downloadable I don't mind. LogoTV seems to split the videos up into chunks so that they can insert adbreaks like there would be on TV.
    Anyway, I'll give the software a try. Thanks for your help!
    Okay, so I tried and it worked! One last question, though: how do I get the HD stream? RTMP Explorer only seems to be detecting the lowest quality stream available.
    strictly speaking.. you are down loading not ripping,
    ripping is too copy from disc
    I didn't see any way of switching at the site. Does it automatically select different resolutions?
    <edit>
    Ah, I see. For some reason Firefox wasn't showing the bottom of the frame with the video. So I couldn't see the controls, including the resolution changer. I don't know how you're going to specify a different res. You may have to resort to using a URL snooper and the command line version of rmtpdump.
    </edit>
    <edit>
    </edit>
    or you can use TubeDigger 3.1.2
