Closed Thread
    I have an .mkv file that I try to play on Sony BDV-E980W Blu Ray Home Theater System but it says "File corrupted or unsupported format". I then opened the file with mkvmerge and without changing any of the settings, created another .mkv. This new file plays on the Sony Blu Ray Player. However, when I try to fast forward, it goes forward for about 1 minute of movie and then quits. It then starts playing next file on my USB drive.
    So, I need help on two issues:
    1. Why the original file does not play on the Sony Blu Ray Player.
    2. Why the FF doesn't work on the newly created .mkv file.
    If anyone has a clue, please enlighten me on this. Here is the file info of the original file from Mediainfo:
    General
    Unique ID : 228847880297561397925974097967544775723 (0xAC2A7FA026AECA569E56E4E7CF63B42B)
    Complete name : K:\Video\Movies\Ek Tha Tiger (2012) 1080p DVDRip x264 AC3 (DST)\dustorrents.com) Ek Tha Tiger (2012) 1080p DVDRip x264 AC3 (DST).mkv
    Format : Matroska
    Format version : Version 2
    File size : 3.85 GiB
    Duration : 2h 13mn
    Overall bit rate : 4 135 Kbps
    Encoded date : UTC 2012-09-27 04:27:43
    Writing application : mkvmerge v5.7.0 ('The Whirlwind') built on Jul 8 2012 20:08:51
    Writing library : libebml v1.2.3 + libmatroska v1.3.0
    Video
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Muxing mode : Header stripping
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 2h 13mn
    Bit rate : 3 632 Kbps
    Width : 1 920 pixels
    Height : 816 pixels
    Display aspect ratio : 2.35:1
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.097
    Stream size : 3.35 GiB (87%)
    Writing library : x264 core 125 r2200 999b753
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=3632 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Duration : 2h 13mn
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 427 MiB (11%)
    Default : Yes
    Forced : No
    Any help will be greatly appreciated.
    Thanks a lot in advance.
    Subhash.
    Thanks.
    Subhash
  2. Member johns0's Avatar
    Please do not ask for help on illegally downloaded movies which are considered warez and is against forum rules,this thread is closed.
