I want to encode the audio track of a BD, what settings should i use to do this with meGUI?
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 2h 34mn
Bit rate mode : Variable
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Language : English
Default : Yes
Forced : No
Results 1 to 11 of 11
i don't know what a audio channel is, will changing it affect the quality? the size of the audio source is 5 gb.
whether u want to keep the original or want them as .ac3 output. So if u decide for .ac3output select it and wait for it to output.
if u like to downmix then choose it but if u want the channel to remain as it is choose keep original channel and sample rate.
Generally the audio will be either 5.1 channel surround sound (front left and right, centre, rear left and right and sub) or simply stereo, but there's a few other surround sound types. Whatever the format, selecting "keep original channels" will keep the audio channels as they are.
The other MeGUI option mainly used would be to downmix the surround sound audio to stereo (smaller file size) but there's a few other options to choose from.
The MP2 and MP3 encoder don't support multichannel audio, so if you choose one of them there's no "keep original channels" option as it must be mixed down to stereo. -
I'm converting FLAC to AC3 for DVD. I know all I have to do is go to Encoder Settings and pick Aften AC-3: Aften - DVD - Good but me being curious I clicked Config and under Preferred Encoder is says NicAudio, FFAudioSource, DirectShow, and BassAudio. Which one of these is the best? Obviously not BassAudio though because I don't want a bass boosted DVD.
Just leave it on NicAudio and MeGUI should try that decoding method first. If it fails for some reason I think it'll step through the rest of the decoders in the list till it finds one which works.
BassAudio is (I think) a dedicated AAC/MP4 audio decoder. Nothing to do with boosting the bass as such.
Encoding audio alone
By kaaviyan in forum Blu-ray RippingReplies: 1Last Post: 26th Jan 2013, 05:52 -
questions about audio normalizing and audio encoding
By codemaster in forum DVD RippingReplies: 2Last Post: 25th Sep 2011, 21:22 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
best audio encoding?
By Remyisme in forum Newbie / General discussionsReplies: 4Last Post: 20th Oct 2008, 04:44
