Folks, please help me. I am a total novice, so please be patient and take me step by step through the process if you can.
I made my movie and want to burn it to a disc now. When I go to "create a movie" though, I cannot get the thing to burn, and twice it messed up my project. Good thing I saved it somewhere else!
I just need some help how to convert my project onto a DVD. I have 4,7GB DVD/R discs (16x speed) My writer is a 32x speed I believe?. My project is 4,5GB big, and 15 min of video and music.
Any help would be appreciated!
Cheers,
What speed are you burning at? In general it should be half the speed the DVD states, so 8x for a 16x disc.
You don't describe very well 'how' it messed up your project can you elaborate a little?
If it gives the option; burn to a folder first, not straight to disc.
If you have a DVD folder already made (with AUDIO_TS and VIDEO_TS folders inside) try burning with ImgBurn. -
I'm moving you to our Authoring(DVD) section. It's for making and burning your own DVDs. DVD Ripping is only for ripping and converting from commercial dvds.
I do not worry about the "messed up" project, as I double saved it and still have the original. Ok, I have the project in a folder like you described, how do I burn the contents of the folder to a DVD AND have the music on it as well?
I'm using NERO at the moment? -
http://www.afterdawn.com/guides/arch...er_imgburn.cfm
EDIT: Remember to set your project to fit a DVD5.Last edited by transporterfan; 2nd Mar 2013 at 08:42.
Pinnacle studio tutorials
By lennylion in forum Video StreamingReplies: 2Last Post: 7th Feb 2013, 13:40 -
Pinnacle Studio 16 Ultimate
By Darin in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2012, 04:41 -
Pinnacle Studio - 2 Menu's.
By Apple 3.14 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jun 2011, 17:34 -
AVI on Pinnacle Studio 14
By jhughes2466 in forum Video ConversionReplies: 4Last Post: 8th Nov 2010, 05:12 -
Having trouble with my Pinnacle Studio 11
By pietra4521 in forum CapturingReplies: 3Last Post: 6th Jul 2008, 15:16
