I'm interested in using a BT878-based capture card (Leadtek WinFast TV2000XP Deluxe) to capture many of my laserdiscs. I decided on the BT878 because I'd like to capture with a square (1:1) PAR in RGB24 or RGB32. I also like having access to the BT8x8 Tweaker so that I can turn off AGC, etc.
Before settling on the BT878, I'd like to see how well it performs on the Snell & Wilcox Zone Plate from DVE. I'm primarily interested in the resolution and chroma frequency response. I know the BT878 has a crappy (notch) comb filter, so I'm definitely not interested in evaluating its Y/C separation performance. (I use the excellent 3D comb filter in my Panasonic DMR-ES10 for this anyway!)
The following link is to an experiment I conducted recently using the Snell & Wilcox Zone Plate from DVE: http://forum.lddb.com/viewtopic.php?p=33347#p33347
Notice that there's no visible resolution loss and the chroma frequency response is excellent!
Can someone please capture the Snell & Wilcox Zone Plate from DVE using a BT878-based capture card via s-video and post the PNG here? The settings you used in the BT8x8 Tweaker would be helpful to include as well.
Thanks! I do appreciate it...![]()
Thread: BT878 Help/Request
"The Cosmos is all that is or was or ever will be." –Carl Sagan
Bump
operating system advice / bt878 / saa7134 / hardware config
By jafvid in forum CapturingReplies: 16Last Post: 23rd Mar 2010, 17:46 -
Resolution Test - BT878 - ATI Rage Theatre - Philips SAA7130
By BrainStorm69 in forum CapturingReplies: 3Last Post: 23rd Mar 2010, 06:10 -
BT878 720x480 troubles
By Venner in forum CapturingReplies: 29Last Post: 10th Mar 2009, 06:48 -
BrookTree BT878 , how to tune tv?
By adiktlost in forum Newbie / General discussionsReplies: 5Last Post: 12th Jan 2009, 16:17 -
Best generic driver for bt878 TV tunners
By ziptip in forum Newbie / General discussionsReplies: 1Last Post: 30th Dec 2008, 02:28
