Hey guys,
I read lots of times on the internet that it is possible to activate the analog and digital input funktion on many Digital 8 Cameras. I have the DCR-TRV325E and I would like to use it to digitize other analog material to DV.
Could you tell me how that is done, without using a service to send it to? Is it easy? Or is it risky?
Get the manual:
http://pdf.crse.com/manuals/3065263321.pdf
Page 100, recording analog video to DV tape.
Page 98, convert analog to digital and send to a PC or DVD recorder, a.k.a. DV pass through. -
Thanks, but that part of the manual concerns not my camera-model, but only the 330. :/ Found this also yesterday...
I thought that the passthru option was removed from most PAL models?
It is, only some of the higher end European spec camcorders will do passthrough. You used to be able to buy a plug in unit that enabled it although whether you still can or not I've no idea (I've got one for an old DCR-TR8000E). I'll see if I can find the box and check if the company that made it still does them (or even exists).
The reason why it is disabled is because the import duty on a video recorder is higher than on a camcorder. A camcorder with analogue in (whether as passthrough or to record to tape) would be classed as a video recorder. Higher duty payable means a higher retail price so, as so few owners are ever likely to use the capability, it is disabled. -
Just checked. The unit was called a DV-in Widget made by a company called datavision. Although their website still exists (www.datavision.co.uk) there is no mention of the widgets any more. I have a feeling that they were taken to court, or at least threatened with it, as the use of their product was effectively allowing people to evade import duty.
if you search around you'll find references to programs/cables that could enable dvin/passthrough for e models. you're not likely to find anyone still selling it other than on ebay maybe.
Transfering Video from Sony DCR-TRV250 by USB on Win7 64-bit
By madadivad in forum CapturingReplies: 5Last Post: 7th Dec 2011, 16:52 -
MPEGs recorded with Sony DCR-DVD108 not compatible with any video software?
By MarcosJP in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 12th Oct 2009, 22:15 -
Transferring video from Sony DCR TRV 285E to PC ...need dv sample
By ganduman in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 12th Mar 2009, 09:20 -
Trouble copying video footage from Sony DCR-HC 40 to LG HDD RH278HB
By klingenberg in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 8th Mar 2009, 10:55 -
Questions for Improving Sony DCR-TRV22 Video Capture Support
By fredberry in forum CapturingReplies: 3Last Post: 2nd Nov 2008, 14:59
