Hi all,
I'm looking to see if a tool exists, that will accept the input of either a wav for avi file and scan through it and find all the blank spots, and report the timecodes.
Essentially, what I am doing is capture numerous 2hr 8mm tapes that have 2-3 second blank spots throughout the tape. Instead of manually trying to find them all, I'm wondering if there is a way at least to automate the process of finding the spots. I would then use VirtualDub to remove them.
Thanks.
Thread: Tool to find blank spots
Actually, this is done often to split a single track of a music album into separate tracks.
Look for a feature like"silence detection" in audio tools.
E.g., the Audacity audio editor has this Silence Finder
If you use Avisynth, the final post in this thread looks promising:
http://forum.doom9.org/showthread.php?t=164864Last edited by AlanHK; 28th Feb 2013 at 02:05.
Best choice for blank DVD media since Verbatims are hard to find
By alvabass in forum MediaReplies: 7Last Post: 28th Apr 2012, 23:58 -
Converting .MKV files with subs to DVD. Cant find a good tool.
By anarchyx34 in forum MacReplies: 15Last Post: 25th Jan 2012, 11:05 -
Remove white spots?
By jwbrasil2 in forum RestorationReplies: 4Last Post: 27th Nov 2011, 01:23 -
find the flash edit tool
By redflower0830 in forum MacReplies: 1Last Post: 1st Sep 2010, 13:22 -
Tool to Find Peak Audio Levels of AVI and MPEG files
By Deluge in forum Newbie / General discussionsReplies: 3Last Post: 30th Aug 2010, 13:47
