Results 1 to 12 of 12
  1. Hi,
    Greetings, this is my first post to the group and nice to meet you. I'm not sure which forum this should be placed in so I'm posting it here.
    I have tried playing DVDs I've burned with DVD Shrink, ConvertXtoDVD 4, Nero 8 and imgburn in both my different computers and two different stand alone players; one a Panasonic & the other a Sony. All of the DVDs play in all of the computers but they often won't play in the stand alone players. I also have AnyDVD 7.1.5.0 installed.
    Some of these came to me as pre ripped as MKV, Video_TS folders and iso files. No matter what I have done thus far, I find roughly 1/2 will not play in the stand alone players. I've been as creative as I can be in getting them to be "stand alone" friendly but I've failed thus far. As they all play in the computers perfectly I am curious what I can try doing to burn these files to DVDs that will play in the stand alone players.
    Suggestions?
    Thanks!
  2. Member hech54's Avatar
    If you are in the U.S. - maybe the video is in PAL format?
  3. Hi,
    I am in the US but when I convert so it will burn to a DVD I have it convert to NTSC by default and I have it strip the region setting to a default of 1. My DVD player is supposed to also play PAL although I haven't put a PAL disc in & I don't know how it would get past the region settings in the player.
  4. Member steptoe's Avatar
    Do they stutter or freeze or just refuse to play. If this is your problem change your media and DO NOT buy bargain bucket media at pennies per hundred. They are that cheap for a reason. Sometimes its good quality branded media that failed quality control so is sold of and other companies sell them as cheap media
    What software are you using as some 'helps' you but messes it up instead, IMGBurn should be your best option as it produces the most compatible burns than most commercial software
    What burn speed are you using, as a LOT of burning software automatically burns at the fastest speed your DVD media or burner can handle, which can and does cause problems. Personally I burn no faster than x8 for DVDs and for install disks as slow as the burner or media can handle. Usually its about x4 now as its very difficult the find media that burns slower than that
    Sometimes how fast your drive can burn is not the best option
    I've read on here over the years the major issues that the USA have with PAL sources, its as if the USA just don't recognise anything but NTSC. If it ain't NTSC we ain't bothering, and region free standalones appear to be practically impossible to find
    The UK is much better in that respect that pretty much any bargain bucket standalone will play practically anything that you put in it. I've had NTSC, PAL and other less common region commercial DVDs I've bought online play perfectly happy with the player happy to work it all out for you, and the vast majority of TV's/LCD's over here are auto-region unless you have a really old TV that is 20 years old or more. So if it detects NTSC/PAL it does it all for you and plays perfectly
    Have a look at AVStoDVD, its FREE and I'm impressed just how easily it handles pretty much anything your give it as a source, and it can convert PAL to NTSC or NTSC to PAL. It uses nothing but FREE software to do everything, and can even burn the DVD after conversion. No I don't work for the creator of it, just like how easy it is, but lets me play with AviSynth for more powerful editing
    It sounds like you've got a dodgy batch of discs - some play on PC, some play on PC and standalone.
    I just had a similar problem myself with some Taiyo Yuden discs - 5 out of a 50 pack (cake) won't play in a standalone.
    So I'm now using Verbatim blank DVDs exclusively as I've never had a problem with them at all.
    I agree with mike20021969 that it's most likely bad media. Standalone players are much fussier about this than PCs are.
    The ONLY consistently good media made any more is Taiyo Yuden and Verbatim (everything except their low quality Life series is top notch).
    Problems with Taiyo Yuden as mike20021969 reports are unusual, but I do know that in the past there were issues with some TY DVDs rated at 16x speed if you burned them that fast. TY makes excellent media, but I do recommend burning at slower speeds. I never burn above 4x myself.
    One other possibility.
    Are you burning DVD +R's ?. Some stand-alones choke on these. DVD -R's give best compatability but do check your stand-alones' manuals also.
    This should NOT be true on ANY DVD or BD player made within the last 5 years. The OP would need really a really old player for this to be true. We do get posts all the time from people still using players they bought 10+ years ago, so it is possible, but it's really been about 5 years since any of the manufacturers made any players that still had this issue.
  9. Member hech54's Avatar
    Here we go again.
    Same BULLSHIT over and over again every chance he gets.
  10. Member Noahtuck's Avatar
    Here we go again.
    Thanks!
    You saved me the trouble of saying it!!
    LOL!!
    Originally a member since 2001, LONG LIVE TARAN's!!!
  11. Heh, no, no stuttering at all. Just get responses that the disk can't be read. Different words on the Panasonic stand-alone vs the Sony stand-alone. Maybe I'm not using anydvd correctly? I just don't know what's with the failures. Since they play in any computer but not in the stand alone ROM, there must be something I'm missing.
    Megalomando, I will contribute to this tread again despite the most useful posts of Tweedledum and Tweedledee aka hech54 and Noahtuck as above. And to these know alls, as long as there exists a player that does not play DVD+R's - I have one - the 'Possibility' exists.
    I will not directly repeat my 'bullshit' but ask that you give some more information.
    1. The Make Model of both your stand-alones
    2. Did you burn all these disks yourself or receive some of them from others ?
    3. Have you always used the same brand and type of media ?
