  1. Hello Guys.
    I send a movie to host (vk) and after conversion, the movie gets "breaks".
    I think the problem is codecs.
    It's possible change it fast? (5/10min)
    Thanks!
    You mean vk.com? The social network?
    You'll need to provide a lot more info. Try opening the file with mediainfo and posting the results.
    Do not start loading up your system with codec packs. That's often the first impulse of the unknowledgable and will probably cause more problems.
    If the file format isn't compatible with what the site accepts you may have to convert it. Sometimes you don't, the converter can just repackage the video. If you have to convert it, well, I've never converted anything in only 10 minutes. Maybe if it's really short.
  3. Right, social network.
    See:
    It's only a example, but i need send big movies to vk (max:2gb)
    Normal Movie (without breaks):
    https://www.dropbox.com/s/krv1f4s7mowi3rk/Movie.rar
    Movie After Converted with VK (with breaks):
    https://www.dropbox.com/s/g6mgphs2hmrhf30/vkmovie.rar
    I need to do the task as fast as possible.
    2gb in 10 minutes, i'm not sure even a repakage can be done that fast, certainly NOT a Re-encode
    as far as breaks, do you mean VK is cutting it into segments/parts ?
    if so your file is too big, re-packing will NOT help, VK will still cut it up into parts
    you need to check the max file size limit and 'total' storage per user limit
  5. Originally Posted by theewizard View Post
    The max size from vk is 2gb.
    See the example in above post, about the "breaks".
    I do not know if the problem is the codecs...some videos work well (withou breaks) others do not.
    well if some stream OK after upload and some do not
    try using mediainfo to check the codec/coding involved
    then re-encode the problem files using the coding that does not cause problems
    but NO it cannot be done in 10 minutes,
    not on my PC, and its a core i5
    re-encodes take time
  7. I solve my problem in 2min. : )
    Only changing to 25 fps.
