Hi all.
I'm a complete newb on this topic, so sorry for any stupid inquiries.
I'd like to be able to record approx 4 different local news channels...take the best video and info from each station on a given story, and then condense/summarize my own story out of it.
My local cable company won't let me grab the video from my dvr. I've done some reading on boxes like silicon dust's products but really don't know how or if they would work.
Any advice or pushes in the right direction to better understand what I'm trying to do would be appreciated.
Thanks-
Thread: Capturing a cable signal
Your local channels are probably sent via clear (unencrypted) QAM. If you have a TV with a QAM tuner see if it can get the channels you want directly from the cable feed. If so, all you need is a capture device with a clear QAM tuner. Note that the FCC recently ended the requirement that cable companies transmit local stations as clear QAM. So even if you get them now it may not be long before they're cut off (encrypted). Cable companies want to force you to rent a box for each TV.
If you can't get what you want via clear QAM you'll need to see what analog outputs you have on the back of the cable box. Most still have standard definition composite and/or s-video outputs. Most also have standard and high definition component outputs. To use those you'll need a device that can convert them to digital. Something like a Hauppauge HD PVR (for SD and HD) or the HVR-2250 for clear QAM and standard definition analog.
http://www.hauppauge.com/site/products/data_hdpvr.html
http://www.hauppauge.com/site/produc...a_hvr2250.html
HDMI outputs on the back of the cable box are almost always protected by HDCP encryption. Few devices will capture encrypted HDMI. There are some grey market HDCP strippers available. But it may be illegal to possess one in the USA.
http://forum.videohelp.com/threads/3...HDCP-strippers -
Generally speaking it is possible to record to the DVR, play it back and record it in real time to something like the Hauppauge HD PVR or Colossus if your DVR can output over component (better quality) or composite (worse quality). I've done that before. Trying to record via HDMI is most often a losing proposition for the reasons jagabo talks about.
I question your wanting to do this in the first place as if you live in the USA, technically speaking the news broadcasts are probably covered by copyright and you may not have the legal right to do what you propose, particularly if you make these summaries available in some public place where others can get to them. But it would likely take a court case to decide on whether what you propose is or is not legal. It may not necessarily fall under Fair Use. In general, the longer the summaries are, the less likely it would be considered Fair Use. US courts have never explicitly defined what is and is not Fair Use so it's all just guess work, but in general in legal cases involving Fair Use, the shorter/smaller the excerpt, the more likely it was to be considered Fair Use.
Cable Length vs Signal Loss
By nkordyjaka in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 11th Oct 2010, 09:31 -
Capturing 720p HD HDMI signal via Blackmagic Intensity wierd interlacing?
By TermiATT in forum CapturingReplies: 22Last Post: 1st Jun 2010, 12:31 -
Card for capturing HD Component Signal
By peez in forum CapturingReplies: 4Last Post: 10th Nov 2009, 09:42 -
Fan accelerates, Check Signal Cable shows on screen, computer will not boot
By JenEricRalston in forum ComputerReplies: 3Last Post: 21st Dec 2008, 08:03 -
Disapperaing analog cable channel on a split signal?
By yoda313 in forum Newbie / General discussionsReplies: 3Last Post: 6th Apr 2008, 09:42
