I authored a DVD using Freemake Video Converter, upon playing the DVD, Freemake's logo was present on the right lower part of the menu screen. Is there a way to remove that logo?
Thread: remove Freemake logo from menu
try an earlier version
Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie -
I have never used the DVD option so I can't say what it looks like, however, if the logo appears on the background image, you might try searching the install folder for the image files and see if you can clone the area out with a graphics editor. I have done this with other programs where I have replaced the logos and backgrounds completely. Make sure you save them back at exactly the same dimensions and type.
I was using an older version, so upgrading to the newest version did the trick. Thanks to all that responded here.
Looking for logo remove software
By livetvbox in forum Newbie / General discussionsReplies: 12Last Post: 3rd Nov 2012, 10:45 -
does Freemake have a menu option for multiply films on the same DVD ?
By soulbug in forum Authoring (DVD)Replies: 2Last Post: 17th Oct 2012, 20:02 -
freemake 2 , great program , but can i have my own menu backgrounds ?
By soulbug in forum Video ConversionReplies: 3Last Post: 23rd Feb 2011, 13:01 -
how do i remove logo
By gangers in forum EditingReplies: 1Last Post: 28th Apr 2010, 14:53 -
Remove Logo Without Re-encoding?
By midders in forum DVB / HDTVReplies: 2Last Post: 10th Nov 2008, 21:07
