Hello guys, longtime reader, first time question-asker-er.
I'm using Xvid4PSP 6.0.4 to convert videos for PSP. The problem is, some of the files are too quiet.
Can Xvid4PSP automatically raise the volume if a source is too quiet, and leave it alone if the volume is fine to begin with? Sort of like Normalizing to 89 dB, or Replaygain Track Gain, or something?
The program seems to have something like that: the Channels and Loudness filter. There's even a button to scan the volume. The problem is, I can't seem to get it to work.
Can anyone give me some advice? Is there a way to set it so all files encoded wind up the same general volume?
Thanks a bunch,
- Short
Results 1 to 1 of 1
Remove or adjust the volume of background music in TV programmes ?
By CompVid in forum AudioReplies: 4Last Post: 31st Aug 2012, 05:53 -
Adjust audio level
By drgt in forum Newbie / General discussionsReplies: 7Last Post: 11th Aug 2011, 13:03 -
How do you know the volume level of each channels in a 5.1 track?
By zee944 in forum AudioReplies: 2Last Post: 7th Sep 2009, 09:54 -
how to adjust volume without re-rendering?
By dora in forum AudioReplies: 3Last Post: 22nd Jan 2009, 01:07 -
adjust the volume
By volam in forum EditingReplies: 9Last Post: 1st Mar 2008, 19:19
