    im trying to convert a video that is 1920x1080 video for my LGTV to play via usb external harddrive. it plays almost everything except SBS 3D video, but its capable of playing them because i have a video thats in WMV and it plays that. if anyone know please help. heres the mediainfo.
    First one is the video that works:
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 1.47 GiB
    Duration : 22mn 41s
    Overall bit rate : 9 305 Kbps
    Writing application : Lavf52.16.0
    Comment : FlixEngineLinux_8.0.14.0 (www.on2.com)
    Video
    Format : AVC
    Format profile : Baseline@L4.0
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=20
    Codec ID : avc1
    Duration : 22mn 41s
    Bit rate : 9 171 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.148
    Stream size : 1.45 GiB (99%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 22mn 41s
    Bit rate mode : Variable
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 20.8 MiB (1%)
    Second One That Doesnt Work:
    Format : MPEG-4
    Codec ID : isom
    Duration : 22mn 41s
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 22mn 41s
    Color space : YUV
    Bit depth : 8 bits
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 22mn 41s
    Bit rate : 128 Kbps
    please help me how to get this to work. Thank You
    Looks like a copy error as your first and second ones seem to contain the exact same information. Please put the correct info in a follow up post for whichever of the two is wrong.
    I changed the thread title
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    Sorry guys for the error.
    format that doesn't work is:
    General
    Format : MPEG-4
    Codec ID : isom
    File size : 2.04 GiB
    Duration : 34mn 41s
    Overall bit rate : 8 434 Kbps
    Writing application : Lavf52.102.0
    Video
    Format : AVC
    Format profile : High@L5.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Codec ID : avc1
    Duration : 34mn 41s
    Bit rate : 8 000 Kbps
    Frame rate mode : Constant
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.129
    Stream size : 1.93 GiB (95%)
    Writing library : x264 core 114 r1913 5fd3dce
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=60 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=abr / mbtree=1 / bitrate=8000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
    Language : English
    Tagged date : UTC 2011-06-19 00:03:38
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 34mn 41s
    Bit rate : 105 Kbps
    Stream size : 26.2 MiB (1%)
    Language : English
    The format that my LGTV plays from my external hard drive is:
    Format : Windows Media
    File size : 1.61 GiB
    Duration : 26mn 51s
    Overall bit rate : 8 602 Kbps
    Maximum Overall bit rate : 12.8 Mbps
    Encoded date : UTC 2010-12-29 11:06:05.582
    SfOriginalFPS : 299700
    Video
    Format : VC-1
    Format profile : MP@HL
    Codec ID : WMV3
    Codec ID/Info : Windows Media Video 9
    Codec ID/Hint : WMV3
    Description of the codec : Windows Media Video 9 - Professional
    Duration : 26mn 51s
    Bit rate : 8 389 Kbps
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.135
    Stream size : 1.57 GiB (98%)
    Audio
    Format : WMA
    Format version : Version 2
    Codec ID : 161
    Codec ID/Info : Windows Media Audio
    Description of the codec : Windows Media Audio 9.2 - 192 kbps, 48 kHz, stereo (A/V) 1-pass CBR
    Duration : 26mn 51s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Bit depth : 16 bits
    Stream size : 36.9 MiB (2%)
    If anyone can help me with the right program or how to convert the first video like the second would be awesome. thank you for your help
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Freemake video converter can convert to wmv with vc1.
