Hello everyone,
I'm having the exactly same problem as the thread below.
http://forum.videohelp.com/threads/2...ring!!!!URGENT
Unfortunately, I can't find a solution since the answered link seems to be wrong.
If I render my video using the "DVD Architect 24p NTSC video stream" instead "DVD Architect NTSC video stream" can I solve the problem?
Thankyou.
http://forum.videohelp.com/threads/2...=1#post1356815
What is your source? -
My source is a uncompressed 720x480 29.97fps avi captured through a TV Tuner (I'm capturing a VHS tape through composite input).
Then, I rendered the file in Sony Vegas using the "DVD Architect NTSC video stream" option. -
Describe what you mean by "flickering" - this can mean completely different things to different people
So there is no "flicker" before you burn? Did you build a disc image (iso), or DVD folders and test them on the computer before burning ? Or did you only test in vegas ? (ie. at what stages did you do tests ? )
I have MTS files and want to burn them onto a DVD a normal player will read
By JaneHarris in forum Newbie / General discussionsReplies: 5Last Post: 24th Sep 2012, 13:10 -
What vid files can a normal DVD player read?
By tenpenny in forum Newbie / General discussionsReplies: 4Last Post: 31st Oct 2011, 14:56 -
BlueRay Rips work on normal DVD player NTSC?
By Reesche in forum MacReplies: 5Last Post: 2nd Aug 2009, 04:27 -
just wondering - can normal dvd player hack to play hd-dvd
By chanra in forum Newbie / General discussionsReplies: 16Last Post: 12th May 2009, 22:00 -
Vdub and DVD Flickering
By Marshallator in forum Video ConversionReplies: 0Last Post: 30th Jun 2008, 13:40
