Hi,
I have an issue with SubtitleCreator (2.3rc1).
It plays NTSC DVD's fine
But when I load a PAL DVD, it doesn't complain, it plays the audio but the image remains black, which is not very helpful when trying to synchronize subtitles.. All PAL DVD's play fine with other media players like PowerDvd or MPC-HC.
Would someone please tell me whether it's a SubtitleCreator issue or something to do with my PC (Vista Home Premium 64 bits) and what I can do to solve it?
Thanks in anticipation for your help!![]()
Computers doesn't care if it's ntsc or pal and subtitle creator uses same decoder for both because they are mpeg2 streams so it shouldn't really matter.
Be sure that you aren't openening/using two instances of subtitle creator or some other player at the same time. It could be some overlay problem. -
Thank you Baldrick for your reply.
The Task Manager doesn't show any other instance of Subtitle Creator nor another player -
You could try Subtitle Edit instead, and see how it supports PALs on your system..?
Thank you for your reply
No problem. It supports PAL like all the other media players and programs that have a video preview.
AFAIK SubtitleCreator is the only program on my system that has a problem with PAL.
I like Subtitle Edit but it doesn't support IFO files and SubtitleCreator is the only one I know that does.
sst/Muxman - DVD doesn't display subtitles
By thinredline in forum SubtitleReplies: 6Last Post: 28th Sep 2012, 11:05 -
Windows Explorer Doesn't Display Certain AVI & FLV Thumbnails
By ezehelm in forum ComputerReplies: 1Last Post: 4th Nov 2011, 15:20 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
VLC problem - doesn't display full length, only plays bits...
By MikeMGMVE in forum Software PlayingReplies: 3Last Post: 3rd Sep 2008, 14:38 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58
