Hi
Can someone please tell me how i can edit dvds so that i can add my own logo to the top right/left hand corners and bottom of the dvd and then be able to upload to youtube.
Which is the easiest way? Less time consuming and easiest?
What software do you use for editing DVDs, if any?
If you have an editor with timelines you can add a transparent PNG overlay with your logos on,
use the alpha channel, picture-in-picture....there are lots of ways.
Then export to an MP4 for upload to youtube.
Your post gave me a reason to test out VideoPad Video Editor
The following was done with a transparent overlay and took about 10 minutes to render to a Youtube HQ MP4.Last edited by transporterfan; 23rd Feb 2013 at 12:45. Reason: Added an Example
AVS4YOU editor...
In the overlay track, place a PNG with a transparent background on the video, which has the logo you want in the position you want.
You can add more overlay tracks if needed.
AVS is not free, but it is inexpensive and is actually one of the BEST editors Ive used!
HTH,
Andrew -
Thanks chaps
I dont have a video editor yet. Can you suggest one for me (pref free or very cheap!).
Thanks -
I provided a sample from a free one! Is that not enough? Click on the link in my previous entry.
Oppsssss.
Sorry thought i had to pay for that. Re-read it & actually says:
"Get it Free. A free video editor version is available for non-commercial use only. If you will be using it at home you can download the free version here."
Thank you so much, i will give this a try
The one I mentioned was as cheap as it comes, does full HD, M2TS, MPG, XviD, X264, etc.. etc..
Andrew
YouTube Upload Settings
By roflwaffle in forum Video StreamingReplies: 5Last Post: 5th Feb 2012, 19:13 -
youtube upload without transcode
By VirtualDoobMon in forum Video StreamingReplies: 1Last Post: 28th Oct 2011, 11:09 -
How to add subtitles to a DVD (VOB file) and upload to youtube
By qi99 in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2010, 14:46 -
How to upload more than 10 min on YOUTUBE
By 3thman in forum Video StreamingReplies: 5Last Post: 6th Mar 2010, 14:59 -
How to upload HD Videos on Youtube
By hzgg2 in forum Video StreamingReplies: 1Last Post: 9th Jan 2009, 15:23
