Results 1 to 10 of 10
  1. Hi Guys
    How to add this type details In screenshots
    http://i.imgur.com/Gwes21d.jpg
    I think Some Software was used it
    can any one Pls Tell me How to Do this
    Pls Help Me Guys,,,,
    Thanks In Advance
    ffdshow's osd
  3. Originally Posted by poisondeathray View Post
    ffdshow's osd
    How To use it
    can u help me
  4. Originally Posted by mike20021969 View Post
    I have Video-Thumbnails-Maker but I want movie details in Screenshots like http://i.imgur.com/Gwes21d.jpg (not top of the pic or right & left Etc,,,)
    To use ffdshow OSD ("OSD" = "On Screen Display") , you have to configure whatever application you are using to take the screenshot to use directshow and ffdshow. e.g. you might use MPC
    In the the ffdshow configuration, checkmark the OSD box, plus whatever parameters you want displayed (current frame, frame type, etc... there are dozens of choices)
  6. Originally Posted by poisondeathray View Post
    anyway Thanks Its not work for me
    Then you probably don't have ffdshow set to decode your video
    Do you see the ffdshow tray icons pop up when you open the video? If not, then ffdshow isn't being used
  8. Originally Posted by poisondeathray View Post
    i was open the video in MPC I can't see the ffdshow tray
    You have to configure it so ffdshow is doing the decoding, otherwise this method won't work . That sample screenshot was definitely using ffdshow's osd
    You might have to disable the internal mpc decoders in the options, you might have to use preferred filter tweaker and/or codec tweak tool to get it working. e.g. if you have lav filters installed you might have to lower the merit or uninstall or disable.
