These remotes sound pretty sweet, but the only thing that is stopping me is the price. If I were to buy an old model (like a harmony 880) used for a lot less, what would I be missing vs. a newer model?
Things I've found that may be different between older/newer model:
Better button placement
Ability to create custom sequences
Old model doesn't offer RF
Better looking mini LCD screen
Other than these I wouldn't know if anything else would be different. From what I understand, Logitech offers firmware upgrades with their remotes so I'm assuming it will recognize all the devices a newer model would. If I have my info wrong or incomplete I would appreciate any additional knowledge on the remote.. Thanks in advance!
Thread: Considering a harmony remote...
I have using a harmony one for a long time now. It works perfect and the harmony computer software finds ALL my devices, even my noname chinese hdmi switcher.
Yep, they are a bit expensive. But it's worth it if you have several devices and you just press one button to automatic switch between tv, xbox, htpc, dvb, receiver. It can take an hour or so to configure all custom sequences. -
Harmony newer models you can try like the 300 series for as little as $5 in some stores here in Canada (Real Canadian Superstore) so it's not like you are breaking the bank...
http://forums.redflagdeals.com/harmony-300i-remotes-4-84-clearance-priced-superstore-1301320/ -
This is my remote.. it is SWEET but expensive
All the models in the Universal selection are great choices
http://www.universalremote.com/products/residential/remotes/mx-3000 -
Thanks for the replies!
@computeguy - Thanks for the link, I haven't really looked into other brands as Logitech Harmony seems to be the popular one. I probably should look at competitors before I make my decision.
I did notice the Harmony 200 and 300 they have out now. I think the 300 controls 3 devices and that would work but I have 4 that I can think of right now that I would want to control. I may be expanding in the near future as well.
I can live with the differences I mentioned above if that's all there is to consider. Used prices for the 'higher end' harmony remotes look to me to be in the $50 to $70 range, even remotes Logitech designed back in 2005. I have found the 880 model out there for even less than that. I figured if the remote was basically the same from back then and now, why pay more?
Sony RDR-HXD970 region free via logitech harmony 700
By dredwerker in forum DVD & Blu-ray RecordersReplies: 0Last Post: 1st May 2012, 03:34 -
Logitech Harmony One and Region Hack. Possible?
By FNakashoji in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Oct 2010, 09:32 -
How to sync WD TV Live Plus HD with Harmony 550?
By tj1182 in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2010, 23:39 -
Does the Logitech Harmony software allow for direct keyboard mapping?
By yoda313 in forum Media Center PC / MediaCentersReplies: 0Last Post: 21st Nov 2008, 13:17 -
Remote
By WildParadise in forum Media Center PC / MediaCentersReplies: 14Last Post: 24th Apr 2008, 10:10
