Hi All,
I was wondering if it's possible to connect a DVR (Motorola DCX 3400-M) to a PC? It's got ethernet, USB, firewire, etc.
I want to capture the video in real-time, so I can edit it immediately. I heard there are hauppage cards. How does it work? Do they create files on your PC? Or does it send the video stream to your PC, allowing you to capture it yourself?
Any insight would be appreciated.
Results 1 to 19 of 19
I provided my input on this in the other thread.
Firewire is best for quality. Give it a try with Mac OS X or a 32-bit version of Windows. -
I didn't say 32-bit Windows just for giggles. It is a requirement, because the person writing the drivers had and has no interest in creating a whole new branch.
Possibly, for analogue NTSC channels only. No HD.
I believe both Shaw and Rogers are actively enacting plans to remove all NTSC channels and replace them with digital versions, in all markets.
What is your cable company? -
And if the past is any clue, cable companies are starting to require cable boxes for unscarmbled reception. On the cable line itself, all channels would be encrypted. Capture cards would be useless. While that is not true in all areas of North America, it's something to think about.
Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau -
Ok so I got a 6 pin to 6 pin firewire cable and hooked up the PVR to my PC, but it couldn't automatically install the drivers. Here's what it says:
I tried clicking the link (which jagabo provided) to download the driver, but the link is broken. Is there another place to get the driver? -
Try here: http://home.comcast.net/~exdeus/stbfirewire/ . That's where I got them long ago.
I tried it and it doesn't work. It says:
"Windows could not find the driver software for your device".
I picked the "drivers" folder where the files are located, and it won't work for either device. Any ideas why?
Perhaps the drivers do not support my 64-bit version of windows 7? vaporeon mentioned earlier in the thread that it works with 32-bit windows only.Last edited by mr-scarface; 28th Feb 2013 at 22:49.
You nailed it. Not sure why I have to say it 3 times and you still don't believe me.
nah I believed you, I was just a bit confused about the whole thing so I decided to go ahead and try that method. Especially since there's some doubt with the capture card method.
I could always set up a dual boot with win7 32-bit just for this purpose, but that's kind of a ridiculous workaround. -
I guess it is pretty easy to install, but it just doesn't make sense for me. I will be editing the videos in a 64 bit version of Sony Vegas, so it just doesn't make sense to use a 32-bit operating system especially when I'm performing resource-intensive tasks like this.
As of right now, I am recording my TV screen with a camcorder, which is FAR from the ideal situation.
How can i capture live sport stream
By stan101 in forum Video StreamingReplies: 3Last Post: 23rd Nov 2012, 14:57 -
Osprey 440 card capture video in mp4 from live stream
By vrparekh@gmail.com in forum CapturingReplies: 1Last Post: 13th Apr 2012, 05:21 -
Screen capture of live webcam stream - which format should I use?
By clemenzina in forum Video StreamingReplies: 0Last Post: 23rd Nov 2011, 05:44 -
Question how to capture live audio stream of KJAZZ
By jimdagys in forum Video StreamingReplies: 7Last Post: 13th Nov 2010, 19:26 -
My new capture card can record and playback, but won't live stream. :-/
By Deadlight7 in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2010, 23:50
I've done them with Shaw in Vancouver and a mid-sized city in AB.
