Hi all, I'm building up a stereoscopic vision system for a microrobotic application and I need some advice since I'm new to this world.
Can you suggest me an affordable device ( 1000 $ or less) that take a video input (S Video, Composite, SDI..) from a couple of cameras, combine them in a 3D format (side by side, frame packing, dual stream..) so I can see the live stream in a 3D monitor?
What about devices like Ultrastudio 3D or Decklink Extreme 3D from Blackmagic? Do they need a PC for stereoscopic rendering or they can process the stream directly with their GPU or whatever?
Moreover, since most microcameras have an analogic video output, is it possible to genlock S-video or composite video?
Thank you.
Results 1 to 1 of 1
Thread: Help with 3D capture device
What's a good capture card/device to capture VHS tapes?
By granturissimus in forum CapturingReplies: 15Last Post: 18th Jun 2012, 22:34 -
Looking for capture device, is this what I need?
By V Bot in forum CapturingReplies: 3Last Post: 21st Apr 2012, 09:16 -
Capture device
By ingeborgdot in forum CapturingReplies: 7Last Post: 11th Sep 2011, 20:02 -
Capture Device
By NMeade in forum CapturingReplies: 7Last Post: 24th Feb 2011, 17:23 -
What device to use for VHS capture ?
By dazz700 in forum CapturingReplies: 3Last Post: 17th Mar 2009, 15:18
