i have an old camera it rec vcd 352x288 25fps 1150kbps and 128kb audio
i wanted to know how to put these on a dvd without them being converted so i can watch them on a dvd player also how many minutes of video will fit on one dvd that is 4.7gb?
Results 1 to 14 of 14
Thread: vcd on dvd
They have to be converted to make a DVD the standard res is 720x480 NTSC or 720x576 PAL you'd be better to make them all divx and put them on a cd and watch them. remember with dvd your upsizing them and it'll look crappy, or leave them in that format and just put on cd and watch them.
dvd player won't reconize them as a dvd unless they're in the standard format.
Video-yes (justs needs reauthoring)
Audio-no, must be converted + src
Amount is simple math: filesize = bitrate * runtime
or put in another way: filesize / bitrate = runtime
So 4.37GiB / 1361.78kbps = ~7 1/2 hours
Clearly, theprevious posters don't have much experience with VCD... -
Which the video is already (but as Scott said, not the audio):
http://www.videohelp.com/dvd
PAL
Video:
Up to 9.8 Mbit/s* (9800 Kbit/s*) MPEG2 video
Up to 1.856 Mbit/s (1856 Kbit/s) MPEG1 video
720 x 576 pixels MPEG2 (Called Full-D1)
704 x 576 pixels MPEG2
352 x 576 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
352 x 288 pixels MPEG2
352 x 288 pixels MPEG1 (Same as the VCD Standard)
25 fps*
16:9 Anamorphic (only supported by 720x576)
OK my main point I guess is the looking crappy part, no? wouldn't the end product be rather pixelated ?
It is not ever going to look BETTER than the original, but with resizing & reencoding it could look a lot worse. And well-compressed MPEG1 doesn't look that bad. More "fuzzy" than pixilated.
Best to leave as is if one can.
Scott -
Dude, don't get all pissy just because you were wrong. Accept it and learn from it.
Whether it looks crappy or not is pure conjecture. It probably does, but without looking at it, we can't really tell. VCD doesn't have to be horrible. Some of the recent ones coming out of Hong Kong are actually decent in terms of quality. You might be surprised. But I'm not in any way suggesting that they are as good as DVD or BD, just that they're also not the horrific mess of pixelation they used to be years ago.
As others have pointed out, VCD video is valid as is for DVD, just the audio needs to be converted to 48 kHz. I do want to point out that many consumer grade DVD authoring programs will not accept valid MPEG-1 for creating DVDs. I've got a test one that I created some years ago using Scenarist, but that's not anything most people here would use. I don't know offhand what else might accept MPEG-1 video for DVD authoring without barfing or trying to convert it. -
I just checked with Muxman and DVDAuthorGUI and they both accept VCD video. I expect you're right, though, that some authoring programs won't accept it.
But that puts the burden of the problem on the authoring program, not the mediafile itself. If they followed the full spec, they should have accepted it.
Scott -
If the original files are mpgs, and you burn them directly to DVD- they'll play in most DVD players. I have copied some of my rare vcds to DVDs by using Isobuster to extract mpgs from the .dat files, and burning them to a DVD. You can burn to a rewritable DVD and check whether it works with your player.
But if you do that, and the audio isn't appropriate, what happens? Some players might play ok, some might freeze, some might play the video silently, some might not play and say what's wrong (the audio), and some just might not play with no explanation. That doesn't get you much closer to your goal, because you might not know whether it is the media's fault or the player's. With standards, like "DVD-Video", you have a clear benchmark of what should play.
Scott -
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 16th Jun 2010, 23:29 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 10:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
karaoke VCD to DVD
By biemew in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2008, 05:16
