I tried Handbrake and it tried, but the pans became quite jerky. Is there a tool that does a better job of converting Apple ProRes format to H.264 on a PC? Or is there some setting in Handbrake that might fix the jerky pans? I tried a quality setting of 12, which still created a large file at 43 Mbps, but still jerky pans.
Results 1 to 10 of 10
Thread: Convert ProRes to H.264 on a PC?
The quality setting and bitrate should have nothing to do with a jerky pan . If anything , a higher bitrate might cause stuttering
What was the ProRes file specs? was it interlaced , etc ? Resolution? Did you deinterlace in handbrake ?
Could it be a playback problem? What are your computer specs ? What software player are you using ? Can you try another player (e.g. mpchc, potplayer, splash, vlc etc...) -
I've had this problem with more than one ProRes file. These are 1080p files, no interlacing or de-interlace settings. They tend to start with a high bitrate of 100+ Mbps. I am cutting the bitrate down close to bluray of 35 Mbps.
Not a player or computer problem. -
Example:
Input: ProRes, 111 Mbps
Output: AVC, 43.6 Mbps
Framerate is VFR. I will try CFR. Didn't think of that. Thanks. -
No change with CFR.
I also tried setting Anamorphic to None.
I haven't touched anything on the "Advanced" tab. -
Yes, both are at 23.976 and framerate was set to "same as source" in handbrake.
Now here's an odd thing - size is NOT the same! MOV is 1888 x 1062, MP4 is 1920 x 1080. Weird thing is that Handbrake claims the MOV source is 1920 x 1080... If I set Anamorphic to None I can edit the size, but if "keep aspect ratio" is selected, the size if off by 6 pixels in the height when I force the width to 1888. Trying it with the box unchecked now at 1888 x 1062, but why doesn't Handbrake properly recognize the size? -
And manually changing the size had no affect.
Got a small sample where this problem can be reproduced?
Need to convert ProRes to 422 HD MPEG2 program stream.
By Randy Burleson in forum Video ConversionReplies: 8Last Post: 27th Jul 2012, 17:24 -
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 02:15 -
Best way to convert ProRes into a format for Handbrake input?
By bugeyes in forum Video ConversionReplies: 0Last Post: 6th Jul 2011, 13:26 -
Most practical method to convert from ProRes to AVCHD
By mikeveli20 in forum MacReplies: 0Last Post: 12th Mar 2011, 15:21 -
How to convert an h.264 MKV with softsubs to an h.264 MP4 with hardsubs.
By hawk16zz in forum User guidesReplies: 4Last Post: 27th Apr 2010, 11:41
