In MPC-HC -> Options -> Playback -> Output -> Audio Renderer there is a list with the following options:
1: System Default
2: SB Live! 24-bit
3: Default DirectSound Device
4: Default WaveOut Device
5: DirectSound: SB Live! 24-bit
6: Null Audio Renderer (Any)
7: Null Audio Renderer (Uncompressed)
8: MPC Audio Renderer
SB Live! is the name of the driver for Creative SoundBlaster Audigy SE.
MPC-HC defaults to the first option "1: System Default", but what do the other options represent ? What do they mean, what is the difference between them, and how do they influence sound quality ? How does one know wich of these options should be selected ? Or "1: System Default" would be the best choice, for some reason ? Or, what audio renderer you select, depends on what video renderer you've selected ?
Results 1 to 1 of 1
MPC-HC Audio Renderer?
By Island_Dweller in forum AudioReplies: 3Last Post: 9th Nov 2012, 11:40 -
Possible to select audio and automatically turn off subtitles?
By kpic in forum Authoring (DVD)Replies: 5Last Post: 21st Feb 2011, 06:59 -
How to select audio channel when converting MKV files ?
By vcd_user in forum Video ConversionReplies: 1Last Post: 23rd Aug 2010, 16:48 -
Does Zoomplayer has it's own subtitle renderer like MPC?
By natsume shin in forum SubtitleReplies: 5Last Post: 29th Oct 2008, 10:37 -
PAL to NTSC - when do i select this option whilst editing & dvd authori
By johnnybravo in forum EditingReplies: 6Last Post: 24th Jul 2008, 10:23
