Is there a good tool can complete both of converting a video to the ISO or VIDEO_TS and compress and burn it to fit the DVD disc?
Dvdshrink can. Since you are talking about a folder I'm assuming this has been decrypted. Dvdshrink can't read the newest forms of protection - it hasn't been updated in YEARS.
But it can open the video_ts folder and go from there. - Use imgburn to burn - I think there is a version of dvdshrink that can be linked to imgburn to burn after conversion - not a 100% sure since I burn separately.
Nearly certain dvdshrink can read iso but don't know for sure.
Fyi you can use dvdfabdecrypter or anydvd to rip the dvd first if you haven't done that yet. There is a freeware version of dvdfabdecrypter but its not updated as frequently as the paid version. Anydvd is payware.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I believe that it is nero which can be used in co-operation with DVD Shrink.
I recommend DVD Shrink and DVD43.
In the cases where these program can't read the DVD, I recommend AnyDVD. Just be aware that you may have to remove DVD43 before you install AnyDVD. I believe that these 2 programs conflict with each other.
Another excellent tool which can do all of the operations that you mention, is DVD Cloner. -
No. I have a memory.
A quick look at your previous threads is enough to tell anyone that they are wasting their time trying to help you.
You either get you jollies creating threads that have ZERO content, or you have ZERO memory as to what people have
told you hundreds of times before.
[SOLVED] Simple tool to compress video further?
By yetanotherlogin in forum Video ConversionReplies: 16Last Post: 18th Nov 2012, 16:18 -
SUPER: How to best convert a video to fit X megabytes (ie 1hr to 700 MB)???
By trale in forum Video ConversionReplies: 1Last Post: 14th Oct 2010, 21:31 -
What's a good tool to re-compress an MKV video
By creamsoda in forum Video ConversionReplies: 3Last Post: 7th Aug 2009, 00:16 -
Need to compress 5 VOB files to fit in one 4.7GB DVD...
By pmolson in forum Video ConversionReplies: 12Last Post: 20th Oct 2008, 17:52 -
Simplest and fastest way to compress LPCM audio to fit on DVD5
By kurbads in forum User guidesReplies: 5Last Post: 18th Sep 2008, 03:15
