Hi! First of all I'm a noob so please bear with me.
I'm playing anime on MPC-HC using madVR+Lavfilters+xy-vsfilter, and when I skip to a beginning of a chapter the subtitles that are supposed to load at that exact time don't appear, but they do appear if I don't skip to them. Any ideas?
Thanks.
Thread: MPC-HC subtitle problem.
Back up to just before the beginning of the chapter? Have the chapter start earlier? Have the sub start later?
If the subs are too close to the beginning of a chapter (and you start at that chapter point) they won't play. Retail DVDs are supposed to take something like that into account. Did you create or OCR the subs yourself, or is this an untouched retail DVD? -
The subtitle loads if I back up a little bit before it, but not if I skip to it. Is there any fix?
Manono is right. You only have 2 options at this point. Move the chapter points earlier or the subs later. You can try another video player and see if they can do a better job.
Individual sub timings can be changed in DVDSubEdit. This requires the DVD on the hard drive and then reburning afterwards. I've had this problem before but forget how much I had to delay the sub at the beginning of a chapter before it would play. I think it's around 300ms or so.
Then it shouldn't be too hard to either change the chapter point or the subtitle start point and remux back into MKV
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 00:48 -
How to take screenshot of MKV using MPC (with subtitle)
By dominator007 in forum SubtitleReplies: 4Last Post: 3rd Mar 2011, 02:29 -
How to move subtitle position in MPC-HC?
By Stealth3si in forum SubtitleReplies: 2Last Post: 14th Feb 2011, 05:46 -
MPC-HC subtitle default
By cheerful in forum Software PlayingReplies: 0Last Post: 30th Oct 2010, 14:27 -
Subtitle not working in MPC HC
By majid_aryaee in forum SubtitleReplies: 6Last Post: 13th Oct 2010, 10:43
