Results 1 to 14 of 14
    hi,
    I can not convert this,need a useful converter :
    Video
    Format : AVC
    Format profile : Main@L2.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Format settings, GOP : M=1, N=50
    Codec ID : 7
    Duration : 7mn 2s
    Bit rate : 670 Kbps
    Width : 480 pixels
    Height : 360 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.155
    Stream size : 33.7 MiB (83%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 10
    Duration : 7mn 2s
    Bit rate : 129 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 6.48 MiB (16%)
  2. Member sanlyn's Avatar
    Convert it to what?
    Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau
    mp4 and mpeg-2
    What container is it currently? To remux to MP4 try Yamb or Mp4Muxer. You may need to demux to elementary streams first.
    it is a video file which is downloaded from youtube
    Youtube videos are usually FLV or MP4. What did MediaInfo say about the container (Format)? You cut that part out of the list you posted. Different containers will require different software.
    no, I sent all data on Mediainfo
    Which converters have you tried?
  9. Member sanlyn's Avatar
    The file name, which was not included, will reveal the type of video -- flv, mp4, whatever.
  10. Member Cornucopia's Avatar
    No you didn't.
    You cut out the "GENERAL" section.
    I just tested it on an AVI, MKV, MP4, WMV, MOV, FLV. They ALL show the "general" section in text mode & text export.
    For MP4, you might not have to do anything...
    For MPEG2, I'd use ConvertXtoDVD.
    If you're on a Mac (your profile doesn't show which platform), ClipWrap.
    hi friends and thank you for your helps.
    this is general section of mediainfo. i have forhotten that.sorry
    General
    Complete name : nb
    Format : Flash Video
    File size : 40.6 MiB
    Duration : 7mn 2s
    Overall bit rate : 807 Kbps
    httphostheader : r9---sn-p5qlsn7l.c.youtube.com
  13. It looks like the audio/video streams are already compatible with the MP4 container/format (in other words, you can copy them without having to actually convert them). I would try FLV Extract. Just tell it to copy both the audio and video to MP4.
    for re-wrapping to mp4 (not re-encoding) you can use avidemux
    video=>copy
    audio=>copy
    format=>mp4
    another option is ffmpeg or some of the ffmpeg GUI's
    ffmpeg -i input.flv -vcodec copy -acodec copy output.mp4
    To re-encode to mpeg2 you can use avidemux as well
    video=>mpeg2
    audio=>ac3 (you probably don't want to keep it aac)
    format=>mpeg2-ps
    If you are making a DVD , you can use all-in-one tools such as avstodvd , which will also author
