Looking for advice on the above situation. 10yr old DLP works fine( except for burning out lamps). Have spent hours researching on line. The BDP-BX59 has the HDMI and a composite Video output. Optical audio output. The latter works fine with my Panasonic receiver. I assume composite video will be analog. Question: If I run the HDMI into a Kanex ATV Pro converter and then A VGA cable from there into the PC (15 pin) input of the DLP will it work, and will it be 720P digital? Is it worth the extra expense of the converter and VGA cable? Thanks for any help.
I would have thought that anything that ends up as 'VGA' will be analogue
Yeah, "VGA" is an analog signal. Just because it comes from a computer, doesn't mean it's ALL digital (the RCA line out from a sound card is analog, too).
The only "digital" video interfaces are (in ~historical order):
1. SDI (& HD-SDI)
2. DVI-D (DVI-A is analog & DVI-I is a combo of the two)
3. HDMI
4. DisplayPort
What resolution a signal is capable of after being converted is dependent upon a number of factors:
1. The converter box's capability
2. The display device's capability
3. The "allowed" HDMI conversion capability/whether the converter box closely complies with HDCP rules.
You probably won't really know until you get the box & test it out...
Scott -
HD video didn't exist at the consumer level (no HD-DVD or BluRay) when your DLP was made. The reason I say this is that it seems to me that unless it is capable of acting like a computer monitor with a greater than 720x480 resolution, your plan may work but it won't give you 720p video.
You're basically just going to have to gamble the money on it like Scott says. I'm not sure that it's really worth trying to squeeze more life out of technology that old, but there's an endless number of people who disagree with me like you, so good luck on your task. -
DLP set has a DVI input. Am going to get an HDMI to DVI cable and try that. Thanks
HDCP compliance is very unlikely for a TV that old. In case you don't understand the importance of HDCP compliance, if the DVI input on the TV is not HDCP compliant then the Blu-Ray player either won't output a picture for HDCP encoded discs, or will play them at a reduced resolution.
Blu-Ray plyer HDMI out splitter
By Wasp-12b in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th Dec 2012, 12:51 -
hdmi blu-ray to tv not displaying
By BroomQueen in forum DVD & Blu-ray PlayersReplies: 4Last Post: 10th May 2011, 15:07 -
Problem with HDMI to VGA on Blu-ray
By Lio380 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Mar 2011, 19:58 -
Is it necessary for a laptop having an HDMI port if it has no Blu-ray drive
By coody in forum ComputerReplies: 7Last Post: 29th Nov 2010, 20:35 -
Blu-Ray 1080i Component VS. HDMI
By nerd_pH in forum DVB / HDTVReplies: 4Last Post: 5th Nov 2009, 12:48
