  1. hello
    i found that QTGMC() is doubling the frames in the video so i have 50FPS and not 25FPS.
    and i see that it is not Damage the quality.
    This enhances the movement and the the movement looks really good.
    but i know that if i will add SelectEven() after QTGMC( Preset="Slow", Sharpness=0.75 ) so i will get the correct FPS rate (25FPS)..
    but in 25FPS the movement is not better.
    but i sow that People recommend for 25FPS..
    why?
    It does not lose frames?
  2. Member sanlyn's Avatar
    PAL DVD is usually 25FPS interlaced. So, to re-interlace:
    ... run some processing...
    AssumeTFF().SeparateFields().SelectEvery(4,0,3).Weave()
    If your original PAL source was BFF, replace "TFF" with "BFF".
    Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau
    why?
    In what context ? There might be some reasons you have to change it to 25p e.g. youtube doesn't support 50p
    If you're leaving it progressive, then keep it 50p . 25p would be half the motion samples
    If you're interlacing it, then that's 50 fields per second , 25 frames per second . It's 25 frames per second, but still has 50 motion samples per second
  4. i dont care about youtube... i playing this on my Xtreamer and PC.
    50P is Better then 25P?
    Do most modern players can play 50P (not DVD players)?
    this is very important question for me.
    i dont know what is the Difference.
    In any case I get a good result ..
    Why is this important?
    EDIT:
    there is no "DVD" in this story..
    Yes 50p is better than 25p - motion is more smooth . You throw away half the frames when you use selecteven()
    Yes PC can play 50p . Modern hardware players can play 50p for SD resolutions , but most currently have problems with 1080p50
    Re-interlacing is only if you are going back to DVD or SD blu-ray . IMO if you're going through the trouble of using QTGMC, you might as well leave it progressive
  6. Originally Posted by poisondeathray View Post
    As I thought. I just wanted to be sure.
    so Why all the releases (movies, series, etc.) are 25p?
    I do not get it .. the Movement is less smooth.
    Because movies , tv series are currently and used to be shot on film (24p) , and sped up for pal regions (25p) . But nowadays, more and more are using digital cinema, but still use 24p
    Soap operas, Sports, use 720p59.94 or 1080i59.94 (in 60Hz regions like North America); or 1080i50 or 720p50p (in 50Hz regions, like UK, Europe)
