Purchased a 32GB unbranded memory stick a few days ago for $7.
It has given me problems.
Copied 24 GB worth of data onto it. Got a message saying drive was full even though i only put 24GB on it. Anyway after clicking ok. 60% of the files had just disappeared completely.
When i right clicked the memory stick (on the 'my computer' view) it says it was full with 19MB free.
Then when i went into it and highlighted all files, right clicked and clicked properties. It said there was only 6GB of data on there.
Wondering if theres a software which would repair errors on it or whatevers causing this?
I'd like to point out i'm unable to see those missing files on 6 different computers and also have reformatted it within windows and deleted the partition and recreated it. Exact same problem still....
Any ideas people?
Results 1 to 10 of 10
Thread: maybe a dodgy memory stick?
did you buy it from fleebay or somewhere like local pc world high street store? then take it back. if from fleebay then sounds like its a fake 32gb, a lot of these around on places like that.it registers as 32gb but its only a 4, 6 gb if that.
or its just faulty.
try
Download test program http://www.heise.de/ct/Redaktion/bo/down…
After download the file, double-click on the zip file and extract it to c:\checkflash
Click on the file - h2testw.exe under c:\checkflash
Ready to test your flash drive Click on "Select target" and then choose your flash drive location in h2testw program window. It will take long time to test all available space. Most of the fake flash drive size is actually 1GB, 2GB, 4GB. I would suggest your select 5GB as start point. It will takes roughly 20-30mins to test.
Click on "Write + Verify", After the test is completed, you will see "Warning" message on result window.
1) 3.7GB is your actual flash drive capacity
2) the rest is junk.
If you see similar test result, your flash drive or pen drive is fake. Good flash drive or pen drive will not have error or warning. -
Hi there.
Thanks for the quick answer.
Yes it was bought from ebay last week.
Yes from what you've described i think that's most likely the case.
This link here: http://www.heise.de/ct/Redaktion/bo/down
Doesnt seem to work i get a 404 error, do you have another for it?
So glad to know theres something out there to check! its amazing!
Thank you. -
aah its ok found it!
http://www.heise.de/ct/Redaktion/bo/downloads/h2testw_1.4.zip
thank u -
try this link, just click on the software link & save where you want.
http://answers.yahoo.com/question/index?qid=20111009224818AApAYrp
if not ill up in a file share site -
SE14man..weren't you at least a little suspicious on that price of $7.00 for a 32Gig stick?
I was a bit suspicious i must admit... but i saw his feedback to be about 90 or so thousand with very few negative so i took my chances!
And you do realize even if it is a 32gb stick, you will never get a full 32gb of storage out of it, same as hard drives.
But for $7.00 ya really can't bitch for 24gb's of storage......
Even my 8gb sticks only show 7.38gb, but still, a 32gb should be close to 30, 29.??
It is kind of funny because my son was just telling me they have scandisk 32gb sticks at his work for around $18.00Originally a member since 2001, LONG LIVE TARAN's!!!
haha
Yes i guess i wouldnt have minded too much if it was 8GB as it was still very cheap but wheneveri even put a GB onto it it just deletes suddenly so its as much as a 1 legged man in an ass kicking competition.
How do I get my PSP videos onto the memory stick?
By Prot in forum Portable VideoReplies: 5Last Post: 23rd Jan 2012, 11:32 -
Converting FAT memory stick to NTFS
By SE14man in forum Newbie / General discussionsReplies: 7Last Post: 15th Oct 2011, 00:47 -
Test the memory stick
By alintatoc in forum ComputerReplies: 2Last Post: 13th Jun 2011, 13:52 -
I having some problem to access my Flash memory stick
By Seasonal in forum ComputerReplies: 6Last Post: 18th Mar 2011, 08:49 -
question about fake USB memory stick
By jimdagys in forum ComputerReplies: 12Last Post: 30th Mar 2008, 23:58
