This is a multi part question and I am more interested in the gear I need to set it up rather than running it cause I won't be running it but I will be getting everything in place.
My Church wants to start videoing sermons and putting them on the website for people to watch when they can't make it to church and they also want to play the sermon live on a TV in the Lobby area. So whats the cheapest way I can set this up? I need a camera, and I need to hook that camera up to the soundboard to get the audio. Then I need that to go to a computer to save it so we can post it on the website. I also need to it run to a TV in the Lobby aprox 50ft away. So what gear do I need to do this cause I haven't set up anything like this before?
Thread: Camera to Computer to TV
Power Producer can capture (and edit later)from a camera but you need a capture device hooked up to your computer, a splitter, run cables from the camera directly to the TV but use splitter to run cables from the camera to the computer too. That's what I'd do if it works.
It depends on the camera you are using as to whether it is easy or not. If you use a splitter to feed a computer and TV at the same time the picture will suffer (be very dark on a PAL system, not sure what affect it will have on NTSC) as you only have half of the signal going to each. If you are using a DV camera, it will have Firewire output, run that to the computer for transferring and run composite video (yellow RCA) to the TV. Use the composite audio (red and white RCA) to the soundboard for audio.
you're right bud I didn't even think about that happening.
Thanks, I'll look up Power Producer and try it with running the cord straight from the camera to the TV.
Sorry, MsBathsheba my mistake it's Cyberlink Power Director I was thinking of that does the Capturing. It's kind of an all in one video production studio software.
Recording more then one camera to computer/computers
By Cazz in forum Newbie / General discussionsReplies: 0Last Post: 7th Jan 2011, 17:51 -
Is WinDV the best for transferring from camera to computer?
By garybeck in forum Camcorders (DV/HDV/AVCHD)Replies: 26Last Post: 7th Dec 2009, 20:44 -
Surveillance camera ---> Computer
By SweeeB in forum Newbie / General discussionsReplies: 2Last Post: 24th Feb 2009, 15:36 -
Digital camera MB vs. Computer screen
By coody in forum ComputerReplies: 14Last Post: 24th Dec 2008, 07:54 -
Streaming from an HDV Camera to my computer!
By Martig in forum Video StreamingReplies: 1Last Post: 18th Jun 2008, 04:16
