Here's a short sample MPEG2.
I created a dedicated thread for this issue so I can get more eyes looking at it. This is an urgent problem for me, I've just found out that my last week's h264 encodings took up double (10 Mbps) the bitrate than normal (5 Mbps) due to the gamma line as below so I need to fix them quickly:
I added ColorYUV(levels="PC->TV") and my video now encodes at the normal bitrate but it increases the brightness of the video so I need to know how to remove that extra brightness.Code:Mpeg2Source("Gamma Problem.d2v") ColorYUV(off_u=10, off_v=-2) org=last Overlay(org,last,0,0,GreyScale(org).ColorYUV(cont_y=100)) ColorYUV(gamma_y=200, off_y=-32) # Removes darkness blur
Jagabo suggested that I should "make sure your levels are within the valid range". I don't know how to do that. I thought the ColorYUV(levels="PC->TV") line did that? Maybe ColorMatrix does that also but I don't want to convert to RGB.
Themaster1 suggested "coloryuv pc>tv levels is a wrong choice because it'll lower UV (255->240) so try ylevels instead and lower the gamma or tweak's brightness with coring=false)". What is the consequence of lowering UV? The video is for viewing on a PC so I thought I was supposed to have the ColorYUV(levels="PC->TV") line?
I'm not sure what code I'm supposed to use for ylevels. Tweak already has coring=false but it made no difference.
Should I just use the code I already have at the top of the page and remove the brightness with -15 bright on Tweak?
Results 1 to 30 of 44
I loaded 2 videos side by side in AvsPmod with histogram. One with ColorYUV(levels="PC->TV") and the other without it. The histogram looks the same on both only the white on the histogram is slightly more bright when ColorYUV(levels="PC->TV") is used. I don't know what I'm supposed to do with that information and I read the Avisynth.org histogram page.
No, the histograms don't look "the same". You place the histogram statement in a script after you make level and color changes. If you place the histogram statement before the lines that make brightness changes, you change the brightness of the histogram. Besides, you are using a filter and values that were designed for a different scene with different problems. The first camera shot in your sample video already has chroma values that are outside the 16-240 range, and the longer close-up shot is already too bright.
What does "removes darkness blur" mean? Gamma_y and off_y won't fix blur. Using your script, the darks are crushed.
In the close-up shot, If by "darkness blur" you are referring to the short depth of focus that always occurs with the use of long telephoto lenses, you're fighting a lost cause. All long telephoto lenses used at wide apertures for indoor lighting will have that effect on background objects when focused on something closer to the lens.
ColorYUV(Levels="PC>TV") sets the color matrix for PC or TV display. It does not automatically "correct" invalid levels.
Why don't you set your own bitrate? I have no idea what a "normal" bitrate means. You use a bitrate that is adequate and suitable for the video at hand. If you don't like the bitrate your encoder sets, change it.
http://jeanbruenn.info/2010/12/29/avisynth-color-correction-improvement/Last edited by sanlyn; 13th Feb 2013 at 07:47.
Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau -
OK I've updated the first post with the sample that the script was originally designed for so the gamma setting is correct for that video. I put the histogram code last in the script so yes the histograms now look different but I don't know what I'm supposed to do with the info I see on the histogram.
I use a CRF encoding setting which is adaptive so it will increase or lower the bitrate as required up to a point. Without the gamma line my videos encode at about 5 Mbps max (normal bitrate) and with the gamma line they encode at double that. Adding ColorYUV(Levels="PC>TV") fixes the bitrate problem but it adds brightness. I can remove the brightness by adding -15 bright to Tweak but is this is the best way to fix the problem? You guys mentioned fixing the levels but I don't know what I'm supposed to do, could you please provide a script to fix my problem?
I don't have time for guesswork and to learn about histograms etc. I will try to learn that stuff in a few months when I have the time. I need to fix this problem today so if you guys know the answer then please tell me. -
You want the blackest blacks in your video to be black, and the brightest brightest whites to be white. But you don't want the histogram to routinely protrude into the yellow areas (Y<16, Y>235) of the histogram. Ignore small excursions by oversharpening halos and noise (you can use coring to eliminate those but it's not really necessary). And use some sense, not every shot is supposed to have full black and/or full white content. Unless you plan to go through your video shot-by-shot just look for a compromise settings that works reasonably well for most shots.
I usually prefer a horizontal graph trace rather than a vertical trace. To do so I use
orCode:TurnRight().Histogram().TurnLeft()
The latter gives both horizontal and vertical traces by default.Code:VideoScope()
If you don't understand what a waveform histogram is these posts might help:
http://forum.videohelp.com/threads/293041-Any-harm-in-using-ConvertToRGB24%28%29-by-de...=1#post1792823
http://forum.videohelp.com/threads/296961-TV-Safe-Colors?p=1812482&viewfull=1#post1812482Last edited by jagabo; 13th Feb 2013 at 10:12.
Telling me how the histogram works doesn't help with my problem of the brightness issue. Am I supposed to add ColorYUV(Levels="PC>TV")? I did so so my video would encode at the normal bitrate instead of double. However the video is brightened when I add that. What should I do to lower the brightness? Tweak -15 bright seems to do it - is that OK?
I appreciate your help but I specifically said I don't have time to waste in figuring this stuff out. If you have the solution then please provide me with the script.
Well....in this case I'll agree with the histogram problem. YUV histograms are focused on luma, as if color didn't matter, and correcting narrow color ranges in YUV is an exercise in futility (IMHO). You can onbly go so far with that colorspace. Still, it's necessary to fix basic stuff in YUV before proceeding -- there's no other way.
frame 202 in your original mpg. Not too bad, but the major problems are the midlevels and chroma. The black levels are too high, and gamma is too high -- that's why your borrowed statement with gamma_y=200 will not work here. And the image has too much magenta. IF you go into RGB to read more thorough histograms and scopes (which IMO are easier to understand) , and use a pixel sampler to read pixel values("Mod" has one), you could have figured this out a long time ago.
After running your script, you've blown away the midtones and nearly smashed the darks. Please forget the "remove darkness blur" business. It's a long-telephoto shot; that will blur the background. Always. Period. Every time. No exceptions. And using Tweak to lower contrast is the wrong move. The color balance has moved from purple to pale pink.
Code:Tweak(Hue=0, Sat=1.5, Bright=0, Cont=0.9, Coring=False) ColorYUV(gamma_y=200, off_y=-32) # Removes darkness blur
Sane gamma effort. I also fixed the right-edge ghosting (in the images above, look at the girl's arm, shoulder, and the side of her face facing the guy. And killed some of that grimy junk on skin edges). It can be tweaked more, even in YUV, but you'd need RGB to finish it off.
Code:ColorYUV(cont_y=10,gain_y=-5,cont_v=-10,cont_u=-30) Tweak(sat=1.5,hue=-12)
Coming out of YUV it's still a bit pink, and there's a lot of tape noise. I tweaked color pretty well in RGB (because it's a chroma gamma problem across a narrow RGB range. Not possible in YUV. Sorry). I didn't post the RGB version. The image above is after using a few plugins in YUV, a couple especially to counter the block noise and the VHS rips in the guy's sweater every time he moves..Last edited by sanlyn; 13th Feb 2013 at 13:56.
Thanks Sanlyn. That helps fix this particular video but that wasn't what I needed help with! I have lots of videos that definately do need the below script such as the video in the first post (this is the brown video from another thread).
The problem is that the red text causes my encodings to use up to double the bitrate than what it normally would. I use Simple x264 Launcher (it's portable and doesn't need to be installed). I've got a pre-setup version here if anybody wants to test what I'm saying. I use CRF 17, preset very fast, tuning film, custom parameters: --tff --sar 8:9Code:ColorYUV(gamma_y=200, off_y=-32)
I figured out that adding ColorYUV(levels="PC->TV") fixes that problem but that also increases the brightness. What I would like to know is if I should be adding that code or is there some alternative I could use that doesn't increase the brightness? If not, then how should I remove the added brightness? Would -15 brightness with Tweak do it? -
You aren't using the script that jagabo originally posted. The original script is: (oops. See edit at bottom of post)
Try this (it should keep things inside the 16-240 range a little better):Code:ColorYUV(off_u=10, off_v=-2) Overlay(org,last,0,0,GreyScale(org).ColorYUV(cont_y=100)) ColorYUV(gamma_y=100, off_y=-32)
It doesn't increase brightness. It outputs the YUV original's range as clamped 16-235 luma. Using the original script and the mod posted above should solve the contrast problem.Code:ColorYUV(off_u=10, off_v=-2) Overlay(org,last,0,0,GreyScale(org).ColorYUV(cont_y=100)) ColorYUV(cont_y=-20,gamma_y=100, off_y=-32)
Many encoders. when they see a source video that has fits of noise and defects, will raise the bitrate. You should not use low bitrates on pre-encoded, crappy source. Why go thru all this work to clean up, then make it worse?
ED: Oops. Nope, I'm wrong. The original script did say gamma_y=200. Hmm, that's a bit high, likely more than needed, even for "brownie". Unless jagabo objects, I'd say make it 100 instead of 200. I ran it with 100 a few times and the brown was corrected almost as well; the result looks more natural.
I think your h264 encoder is objecting to excessive contrast beyond the 16-235 preferred range. Lowering gamma and contrast should help with that. That's still a very noisy video. You'll need more data bits to handle all that noise.Last edited by sanlyn; 13th Feb 2013 at 16:05.
I did what you said and used the code below but the video still looks a little too bright and blurred when I add the first line:
Also you mentioned that I used low bitrates but 5 Mbps in h264 is the equivalent of 10 Mbps in MPEG2 (DVD has a 9.8 Mbps max) so it's not really low. I'm using McTemporalDenoise & QTGMC as well to remove noise but to keep things simple I just asked for help with the brightness issue.Code:ColorYUV(levels="PC->TV") ColorYUV(off_u=10, off_v=-2) org=last Overlay(org,last,0,0,GreyScale(org).ColorYUV(cont_y=100)) ColorYUV(cont_y=-20,gamma_y=100, off_y=-32)
I wouldn't use the PC-> line. Actually it isn't too bright, it just has 0-255 squished into 16-235, so the black levels look a little washed out. They wouldn't look that way on TV, because RGB16 is "black" on TV. Anyway, lowering brightness with Tweak won't work the way you think it will with that code -- you'll end up with crushed blacks again, which is another bit-hungry encoding problem.
You should be able to set your own bitrate. That video still has lots of compression and tape noise; you would have to filter the heck out of it to clean it all, and there wouldn't be much video left. I'd have to say there's a reason why your encoder wants more bits. But think of it this way: noisy or over-sharpened or over-contrasty source = higher bitrate demands. There's really no good way around it, short of getting a bit-starved video. And somebody flying across the ring and taking 6 bounces back and forth = more bitrate. I'm surprised your encodes weren't higher earlier.
5 mbps for h624 isn't all that low for fast-action video. More activity means more bits, or you get with motion artifacts and block noise -- which is a big defect with those low-bitrate MPEG sources to begin with. The modified script (without the PC>TV line) ought to lower contrast and pull in the luma and chroma values closer to 16-235. Other than that, you have a problem video -- which is what I think your encoder is telling you.
All I use is TX264 or TMPGEnc Mastering Works, so maybe someone who uses your software could suggest something.
You can only imagine how much cleaner those old mpeg transfers would have looked with higher bitrates. They would have been easier to denoise and re-encode.Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau -
Mm, no. Won't go thru that one again. Make four color patches at RGB 0, RGB 6, RGB 10, RGB 16 using an sRGB color space. Make one ramp each of the 4 RGB values for black, Red, Green,Blue. Burn it to DVD or BR disc. Run it on your TV and post a picture of how your TV can display the 16 different shades of color.
Every TV calibration disc you can get sets RGB 16 as IRE 0.
But I agree. If the O.P. doesn't have time to learn what he's doing, he shouldn't be working to get up a collection of bad videos. He needs to hire (or find) someone who can show him, scene by scene, what to do. Or do it for him. Nothing personal. I'd like the O.P. to have his collection. But this is not rocket science. If a dummy and general klutz like me can do it, anyone should be able to.
Anyway, V.R., keep trying. You'll get there sooner or later.Last edited by sanlyn; 13th Feb 2013 at 19:13.
Every TV and computer monitor I have ever had will show the difference between RGB 0 and RGB 16.
There's your problem. sRGB is the same levels as YUV. So sRGB<16 should all be black. RGB is full range from 0-255. What you see in VirtualDub is RGB, not sRGB. Of course, there's nothing to stop you from using a PC.601/709 matrix to convert that RGB as if it was sRGB. But you have to go out of your way to do that because it's not "normal". -
Clarify if you mean sRGB or Studio RGB . These are 2 different things
I agree with jagabo - every TV - even el cheapo ones - can definitely distinguish between RGB 0,0,0 vs RGB 16,16,16 . Most can distinguish between 0, 4, 8, 12, 16 .
I just tested this on several TV's. Both from a jpg image (some of my tv's can play images directly), and also from video converted to YUV using Rec601. Both display the same -
Ah. So I don't have to worry about RGB 16-235 ? That being the case, RGB 0-255 should look pretty good on every TV I see, even those with ISF calibration, and no problem encoding with those values. Won't have to admonish others for using RGB 0-255 for video, and don't have to explain stuff like crushed detail, disappearing noses, etc., etc.
I wonder why it looks like crap on TV, though.Last edited by sanlyn; 13th Feb 2013 at 21:02.
What looks like crap ? If it's properly calibrated, the pure black point should be black, pure white should be white
You have to worry about legal range video , Y' 16-235 , CbCr 16-240 . RGB histogram is less useful when looking at YUV values for video, because the method in which you convert to RGB can change those values. It's when YUV values are "illegal" that you should worry, because those values will not be seen
RGB 0-255 is fine, when you convert to YUV using Rec 601 matrix or 709 for HD. This "maps" RGB 0,0,0 to Y' 16 , and RGB 255,255,255 to Y'235 . The reverse is done when you view the YUV video on an RGB display in 99.99% of hardware and software - so you see black and white the same as you started . This is why Rec601 and Rec709 are the standard for broadcast, hardware devices, DVD players, blu-ray , flash, even portable devices like ipad, ipod, "ithingys"
The exception is "studio RGB" used by some software (notably Sony Vegas) . This maps RGB 0-255 <=>YUV 0-255 -
Yes, and another common exception is Canon DSLR's which record h.264/mov - they record full range (along with full range flag in the bitstream). Using the standard Rec601 (i.e disregarding the full range flag) will clip shadows and highlights , it must be converted to RGB using full range, or a using a decoder that clamps the YUV output to Y'16-235 (e.g. quicktime) before the RGB conversion
So when I set up my yuy2 AVI for color correction in VirtualDub, Photoshop, AfterEffects, etc., I ignore their setup? For example, Color Finesse has a template that automatically rolls off brights from RGB 220 on up, rolling off to RGB 240. You can see it happening on their histogram, even when working in YUV. You're saying I should disable this feature and juice up bright white to 255? I set up a black-point in Photoshop for RGB 16, so the darkest black-point won't fall below that value. So I should always set the black point at RGB-000 for TV video? When I set up a TV with a pluge pattern for blacks, I should make certain that a black patch sits at the darkest plug level ("below black")? What's that stuff all about?
Maybe we're talking about different things. I owned one CRT TV 8 years ago that clearly displayed values below RGB 16 when using calibration test patches. That's the only TV I've owned that could do that. The old SONY Wega couldn't even come close, and my new HDTV's don't know RGB 0 from RGB 16, even when I yell at them. My colorimeter set on the TV screen seems to know the difference, but my TV's are ignorant below RGB 16 (well, actually, that patch has a subtitle that says IRE 0, but on my PC monitor that same patch displays as RGB 16 according to my pixel sampler).
Yeah. I think we're talking about different whatchamacallits. For 15 years I've had success working within 16-235 videos on the computer and having no problems with it on any TV I've played them on, even those godawful uncalibrated Panny and Sharp TV's playing in Volcano Mode. I think I'd better stick to what's been working so far.Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau -
I'm wondering if you're mixing up the readings on the test videos? The videos will be YUV if it's on a DVD. Did the markings say "RGB" ?
The absolute bottom line is you need to adhere to legal range values. Period. This means Y' 16-235. Y' 16 is "digital black" , Y' 235 is "digital white" . (Sure you're allowed a bit of overshoot and undershoot, but you should stick mostly within those values) . Notice RGB isn't even talked about.
Monitoring and measuring RGB is less useful, because you're not delivering RGB. YUV is the delivery format. There are dozens of different ways , in which you can convert the RGB to YUV and back and forth. It's those conversions that are the source of all the headaces.
If you've been using RGB 16,16,16 as "black" and RGB 235,235,235 as "white", then you must convert to YUV using a full range matrix. This will map black at Y'16, white at Y'235.
I doubt that your HDTV can't display between RGB 0,0,0 vs RGB 16,16,16 . This is quite a visible difference. If your TV or blu-ray/dvd payer can read JPG images, feed it a JPG image . Most likely you mean between Y' 0 and Y' 16. I suspect you're mixing something up or didn't do the test properly
For the pluge bar, you should see the visible demarcation between 7.5 and 11.5 IRE - but this is an analog test signal sent by equipment. If it's from another source, it's hard to say what it should be... -
Sanlyn, you're right. The video looks virtually identical on my TV with or without the ColorYUV(levels="PC->TV" line. I take it there's no way to emulate on my PC the exact way it would look on my TV?
The video I posted earlier with the darkness corrections you guys said it didn't look right as that video wasn't meant for the corrections given. I just viewed it on my PC in AvsPmod and thought the corrections looked better but you pointed out all the imperfections caused by those corrections. That's why I was reluctant to meddle with ColorYUV as it's easy to make mistakes like that. I'll just use that darkness correction line on videos with really obvious darkness problems. I don't think I'll be meddling with ColorYUV again. -
Me think you may want to reconsider:
with pc>tv:
http://imageupload.org/en/file/246976/with.jpg.html
without:
http://imageupload.org/en/file/246977/without.jpg.html -
@jagabo + poisondeathray, as it's impossible (Okay, impractical) for me to hook my PC's to HDTV sets, I'm forced to use a couple of IPS LCD's and Windows PC's to process video. All this viewing is done with monitors/TV calibrated with EyeOne colorimeters and the proper software for PC or TV, with accepted SD and HD calibration test patches for grayscale, saturation, gamma, primary/secondary CIE adjustment, and all that. I can't afford a $1500 Lumagen, so I use SD and HD material on DVD/BD discs for the TV's. Can't say what JPG photos look like on my TV's, which are calibrated for disc playback and cable.
Enjoy your component cable setup while you can (as I do), they are disappearing from TV's and from a/v receivers and disc players alike, replaced by this horrid/freaky/paranoid/dumbass HDMI junkware for the toy crowd and the hearing/seeing/match-the-red-plug-to-the-red-hole impaired who truly believe that all wire and everything "digital" looks and sounds alike, and all analog is Evil. Not using my TV as a photo viewer; seeing how digital cameras (and especially cheap digital cameras, iphones and whatnot) are so crippled compared to film, I find that looking at JPG's on TV (or even on my PC) is one of those yawn-inducing experiences that just hasn't wedged itself into a niche in my daily schedule.
So a PC is what I use to correct and arrange video for my TV and others. I realize there are molti problemi going from YUV -> RGB and back. I make those conversions only as needed, and only in the careful and prescribed manner learned here and elsewhere, even down to using dither() for it, never allowing software to make its own permanent conversions a la VirtualDub, setting PC hardware and software to mimic BT601 or 709 display according to instructions, and all that mind-boggling + time-consuming stuff.
So I realize that one of my TV's, and one of my former CRT's, could be used as an RGB 0-255 device. But one of the tv's doesn't fare well as a full-range PC display and doesn't like cable broadcasts that sneak from the cable boxes with illegal luma and chroma down there in the RGB-0 range (or even lower). Back when I first started ruining my sanity with this video hobby, I said bah-humbug to all that invalid video superstition+voodoo....until movies that looked gorgeous on my then-alive CRT started looking like doodoo 75% of the time elsewhere, and like blocky, blotchy trash on LCD's. So I learned to look at video in properly converted RGB with PC stuff that purportedly treats YUV the way a TV would. I realize it's not an exact-science transition from PC to TV, but I try to get close to the mark. My target is still the "standard" TV that works within a 16-235 box, one that doesn't try to be an all-purpose m/m 'bot-twitter extravaganza.
Anyway...."'God bless us, every one!', said Tiny Tim."
How to increase the bitrate of a video by avisynth ?
By avengerevenge in forum EditingReplies: 31Last Post: 11th May 2013, 00:13 -
Avisynth equivalent of VDub brightness/contrast/gamma
By Mephesto in forum Newbie / General discussionsReplies: 37Last Post: 31st May 2012, 10:48 -
Doubling my 720x480 DV size
By televisual in forum Newbie / General discussionsReplies: 2Last Post: 20th Feb 2012, 15:05 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Gamma encoding for PAL DVD
By absence in forum Video ConversionReplies: 0Last Post: 9th Jun 2009, 08:53
