Results 1 to 11 of 11
    Hi,
    I'm not sure if I've done this right, as it is my first post in VideoHelp
    Basically, when rendering full HD video, the render times are very long (45 mins for a 1 min clip)
    This is my set-up >>>
    Windows 7 Professional 64-bit
    Adobe Photoshop CS5 Extended
    Pentium Dual Core E6600 3.06GHz
    8GB Ram
    nVidia GeForce GT 640 GPU
    1TB ATA HDD
    And these are the settings I am using to render video in Photoshop >>>
    Exporting as 1080 HD Quicktime
    H.264 compression - compressor quality = High
    Frame rate as original
    Key Frames = Auto
    Data Rate = unlimited (but doesn't seem to make much difference, even if it is limited to, say, 2,000kbits/sec)
    I am wondering if I am doing something wrong!
    Thanks,
    Dave
    Probably this: "And these are the settings I am using to render video in Photoshop"
  3. Member Wolfen's Avatar
    Sry, didn't realize what you were doing.
    1080p h.264 encoding on a Pentium D = very slow
  5. Lone soldier
    E6600 is a C2D, no Dual Core. Its has overclocked too.
    Claudio
    Sorry, my mistake. Even an overclocked Core 2 Duo E6600 will not be fast with 1080p h.264. For more speed switch to x264 and run with the veryfast or superfast preset.
  7. Lone soldier
    jagabo, for me its a troll...Serious.
    PS to encode video??
    Claudio
    I've seen references to scripts that let you do that. So the OP is probably serious.
  9. Lone soldier
    I tested using a 10seconds gif (320x240) to same spces from OP, compress time is 10 seconds on my PC.
    Very strange 45mns.
    Claudio
    "The script is designed to take a sequence of images, and convert them into an H.264 quicktime file"
    http://www.mikecushny.com/tools/photoshop-script-seq2qt/
  11. Lone soldier
    Virtualdub. Easy, Faster and Better.
    Claudio
