Hello
I have an mp4 file that i wish to add hardcoded subs. Im familiar with this process with AVI files using virtualdub but that tool doesnt seem to work with mp4. Im after something that is simple to use( of course)and where i can ensure no loss of quality to the videofile(mp4).
Thanks in advance.
You will lose quality by reconverting. But you should be able to keep almost similar quality if you do it right.
You can use virtualdub with a mp4 plugin, see http://forums.virtualdub.org/index.php?act=ST&f=7&t=19488. But you can't export directly to mp4 in virtualdub.
Or else can you use xvid4psp, tencoder, freemake video converter, video to video converter to burn in subs and convert directly to mp4. -
They must be in ssa format or vobsub and you can multiplex the ssa to the mp4 with for example mymp4boxgui.
https://trac.handbrake.fr/wiki/Subtitles
You can try use subtitle edit to convert the srt to ssa.
Workflow for Vegas rendering, and hardcoding subs to a DVD and MP4?
By vorton in forum EditingReplies: 3Last Post: 3rd Aug 2012, 11:16 -
hardcoding subs
By zammil in forum SubtitleReplies: 27Last Post: 24th Sep 2010, 04:10 -
Help hardcoding subs to mkv
By striker9 in forum Authoring (DVD)Replies: 1Last Post: 16th Aug 2010, 02:01 -
Hardcoding subs problem?
By elliottpen in forum ffmpegX general discussionReplies: 9Last Post: 22nd Apr 2010, 18:24 -
Hardcoding subs into H264 video and converting to MP4
By muhali5 in forum Video ConversionReplies: 4Last Post: 28th Aug 2009, 10:57
