Object/goal: I have been using an Aqua view underwater video camera on the lake, (12 volt source). I would like to take the video out from my Aqua view, which has a plug for video out, an record it on one of these 2 camera's, Zero background here, (the aqua view video is real time, no way to save it or capture it at the camera
So can I take this output and save it to the video camera cited below?
THE VIDEO I have is a Digital 8 handycam Sony: I have on the side of the Digital 8 a inspection dust cover rubber covering 3 plugs, (similar to what u would see to plug into charge your cell phone) one with a diagram of a small pitchfork, one with the wording beside it, says DV in/out, the other is a blue plastic hole (lanc). Please excuse my ignorance ...
Id very much like to record what the visual image is come off the aqua view camera, keeping in mind IM in a boat with 12 volt power only.
I also have a kodak sportsman video camera about the size of a cell phone, I dont think it has any ability to recover an input signal
if im on the wrong site or better served else where any heads up thanks,
Results 1 to 16 of 16
The pitchfork is the symbol for a USB port, the DV port is also know as firewire port and the blue hole is most likely the analog input. You should have a cable with yellow, red and white RCA plugs at one end and a 3.5mm (1/8") headphone type plug at the other (it should have 4 segments). Connect the Aqua View to the yellow RCA and use the Handycam as a VCR.
if anyone is still read my local guru tells me my video Aqua Camera is analog and the HandyCam is ditital so i guess im dead in the water b4 I start
No you use the HandyCam as a vcr to record incoming video. Please post the model number so we can determine if your camera has a video input. Connect the output of your Aqua Camera to the input of your HandyCam.
No you aren't. A Sony Digital8 camcorder can usually accept an analogue video signal from an external source as well as from the lens. There should be a 3.5mm jack socket on it which you use with the proper Sony cable. Find out what model it is and you should be able to download the manual.
Totally depends upon the model. Some have inputs + passthrough, some have inputs but no passthrough, some only have outputs. Need Model #.
Scott -
The manual is here http://www.docs.sony.com/release/DCRTRV730.pdf and page 74 tells you how to do what you want. That will record your footage onto the tape. To get it off the tape onto your computer see page 60, use the i-Link cable (Firewire) but use a computer rather than a VCR.
richard after i have it recorded on the tape in camcorder (digital 8) unit, AmI correct in assuming the tape plays back just as if the camcorder had filmed a scene its self thanks I have the manual but I really need me to tell me to go to page 64 just like u did for me big help.
IM trying to start a new buss. and for the inital start up this equipment i already have may be enough to satisfy my customers.
if im sucessful Ill soon be upgrading to the right equipment -
I don't know what you mean when you state
. Do you mean the quality of the video or the time and date display that the camcorder generates?back just as if the camcorder had filmed a scene its self -
excuse my question, Once the Aqua camera sends the signal (video) to the camcorder, and it has been hooked up properly, its viewable correct in playback mode,
Old Sony Handycam to PC
By cincy_kid in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 26th Jul 2011, 23:05 -
Want to Upgrade my Sony Handycam
By HoosierGuy in forum Camcorders (DV/HDV/AVCHD)Replies: 13Last Post: 9th Jun 2011, 10:34 -
Problem with Sony Handycam!!
By FrontierGander in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 3rd Aug 2009, 21:23 -
Cannot read sony handycam dvd-r
By DKIT in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2009, 13:56 -
Analog to digital pass through with Sony Handycam DCR- HC65
By Gerald Sr. in forum CapturingReplies: 3Last Post: 30th Sep 2008, 23:18
