According to http://www.videohelp.com/glossary?A#Antialiasing:
Why would that be?When creating DVD Menu text, antialiasing must not be used.
Thanks,
Francois
I think they mean text in sub-picture highlights for the menu selections, not menu text that is always visible. In my experience attempting anti-aliasing for sub-picture highlights makes the highlight less readable.
DVD subpictures use only 16 colors. Antialiasing will create many different colors. The color reduction for subpictures will screw them up.
You can use only 4 (only3 if you do not count background) for sub-picture at a time. So if you want to use anti-aliasing you have only 2 more colors to make it so, each color for different shade. You can do it in Photoshop or maybe latest subtitle creators can do it too automatically, not sure.
Check it out here: http://home.comcast.net/~c.linke/dvdsub/ -
Anti Aliasing caused by field shifts
By Akai-Shuichi in forum RestorationReplies: 17Last Post: 7th Dec 2012, 19:03 -
Please suggest good AviSynth Anti-Aliasing & Rainbow Remover scripts
By VideoFanatic in forum RestorationReplies: 0Last Post: 30th Nov 2011, 06:54 -
anti-aliasing
By anthell in forum RestorationReplies: 4Last Post: 7th May 2010, 22:08 -
Anti-Aliasing Photoshop titles
By kippard in forum EditingReplies: 0Last Post: 6th Feb 2009, 17:01 -
Blurred Text on DVD Menu
By boofer in forum Authoring (DVD)Replies: 3Last Post: 10th Jan 2009, 17:45
