i have video and the audio is OK but 1 minute shorter than the video, which is 5:50
How do I change the video so that it keeps every frame but shortens it to 4:52, the original audio length?
i've tried changing the framerate from 29 to 25 but maybe i did that wrong, idk?
looking for subs: Höök tt0997023 - Lime tt0269480 - Desideria tt0081724 Mafiosa tt0807686 La clé sur la porte tt0077348 tt=iMDb.com
Since frames per second or "FPS" is Frames / Seconds, and you want to keep the # of frames while shortening the length, you have to do this:
# Frames / Length = #FPS
X frames / 5:50 = 29.97fps
X frames / 4:52 = ?fps
Solving for ? means X frames = 29.97fps * 5:50 = 30 frames/second * 300 seconds = 10500 frames
Plugging it back into the equation:
10500 F/ 4:52 = 10500 frames / 292 seconds = ~35.95 or 36FPS. Simple math
But that's kind of silly, because nobody in their right mind is going to use such a non-standard video framerate. Ask yourself: does the video show the motion at the right speed already? If so, you should be adjusting the length of the Audio, not the Video.
Scott -
Scott is correct. The best program that I've found to do this is Goldwave which has an option to timewarp the audio but it is not free. Others have used Audacity which is free but I could never figure out how to do it with Audacity. Maybe someone will chime in to explain just how to do it in Audacity.
Goldwave has a fully functional evaluation version...
http://www.goldwave.com/index.php
http://www.goldwaving.com/downloads/gwave568.exe
Open your video in Virtualdub and go to the last frame. Note the time code at the bottom of page. Either save the audio in Virtualdub (file>save WAV) and open in Goldwave or try opening the video itself in Goldwave. Go to Effects>Timewarp and add the timecode that you noted in Virtualdub (5:50.xxx) and clip OK. Select all>Save as>file of choice (yourfile.mp3). In Virtualdub, select Audio>Audio from other file and select yourfile. Test to make sure it plays right and direct stream copy audio and video and save as new file. -
You have to "re-time", or "undersample" the playback rate, then the length will shorten.
Video and Audio different length
By pchan in forum AudioReplies: 3Last Post: 15th Aug 2012, 03:46 -
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 08:08 -
Audio length do not tally with video
By shans in forum Video ConversionReplies: 4Last Post: 7th Apr 2011, 11:11 -
flv with no video length
By tv3636 in forum Newbie / General discussionsReplies: 6Last Post: 30th May 2009, 15:47 -
Calculating Video Length
By scan in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2008, 12:33
