hi i have a few favorite movie scene i d like to put in one clip
like take 2 min from movie 1 then sort of transition with title then 3 min from movie 3 you see
i need to be able to cut at exact time from 1m54 to 2 39 ...
free soft suggestion plz thx user friendly
win seven x64
psif any can do text to speech would be a plus but not necessary
tell me if limitation comes with them like number of minutes max or 30 day stuff
tx
Results 1 to 10 of 10
It depends on if all the clips are the same bitrate/resolution otherwise you'll be re-encoding them. I can only tell you what I use that is totally "FREE" and fully functional. I use Freemake Video Converter as my DVD Decrypter/Ripper/Converter(you can cut pieces out of the clips). If you want to give it a try, watch when installing that you uncheck boxes that are checked or you'll also install the toolbar which obviously is unnecessary.
I can suggest a freeware and quick way to do it, except there won't be any transitions.
1. Get DVDshrink
2. Use DVDshrink's re-author mode, to rip the three segment into three folders.
3. Start a new DVDshrink project, and use re-author mode, to add the three segments into one video, and export.
4. Done.
Using dvdshrink will work fine if it's a dvd or ripped dvd (ie. a video_ts folder) source. Otherwise I don't think so.
Generally with free / cheap editors you can only cut on what's called a key frame. I'm not going to explain what that is ... look it up ... but that means you probably won't be able to cut exactly where you want. Whether it'll do smarter editing depends on what type of video it is.
The editor I mostly use (not that much really though) is avidemux. Version 2.5.4 (which is the newest thoroughly tested linux version) will only do smart cuts with xvid files. Apparently 2.6 will do this with h.264 but I haven't used it.
Avidemux ain't that noob friendly though, but . Frankly I don't know of any really good free editors, period, let alone good and easy too.
However I don't think the cheaper paid ones are any better. Except for something involving standards like dvdfab I'd say that media software is something where you do not get what you pay for. Unless you're talking serious pro stuff. Which isn't easy.
As wolfen indicated, it's not really possible to say without knowing what the specs of these videos are. But I disagree about freemake. I tried it and thought it was junk. -
ok so from what i understand the
first thing to do is to translate the original (mp4 avi wma dvdrip) vid into the same type
and then
second to use a video editing free soft right?
freemake video would be for one right?
and for part if key sequence are already cut parts i would prefer to personally choose beginning and ending. so wich soft does it free? -
i have a friend that puts classics on my usb key and i never know what .something it is going to be
why -
got some dvd i bought my selftoo if you question is about knowing legality
No, I wasn't asking about legality....if you withhold information, how can anyone know what you are doing?
This forum is not made up of mind readers.
Be as thorough as possible else those reading will have to guess at what you are doing.
So...what do you want to do?
Perhaps our answers can be as cryptic as your information? -
as i said in message one i want to make a compilation of scenes i like
ex love scene best scenes compilation
i want to make a clip that the 2 firts miite will come from movie A then 2minutes from movie B then 3 minutes from movie C so one
does that help
Can you help me to decide wich software to buy from the following?
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2011, 08:05 -
Help with mp4/3gpp wich won't play
By Marty__Mouse in forum Newbie / General discussionsReplies: 8Last Post: 15th Apr 2009, 04:12 -
Wich one is the best option?
By thenamelessthing in forum DVD & Blu-ray RecordersReplies: 18Last Post: 25th Aug 2008, 13:21 -
Toshiba HD-A2 or HD-A3 wich gives the Better Picture?
By ofield1 in forum DVD & Blu-ray PlayersReplies: 16Last Post: 7th Mar 2008, 11:23 -
wich format?
By logicmich in forum SubtitleReplies: 0Last Post: 20th Feb 2008, 12:00
