Hi I'm trying to edit file tags on my video files and I found a program called abcavi... the only problem is that I get errors with it when trying to save and it is a really old program... So is there a better program out there for editing video file tags?
Please check out my other forum post thanks: http://forum.videohelp.com/threads/353153-Multiple-issues-with-WMC-WMP-regarding-Xbox-...57#post2218257
may be MetadataTouch (trial-/payware)
avi container specification hasn't changed for a long time,....and it is a really old program...
care to elaborate on that? maybe it's a simple to fix known problem,...the only problem is that I get errors with it when trying to save
no clue about Xbox,...Please check out my other forum post thanks -
If I edit the "Title" field of an avi and click save in abcavi it says error wa unable to save "".
Works fine here.
-> Does this happen with all your avi files or just with some?
Got any non common characters in you avi file name? (try if it helps to rename it to test.avi)
Check that your avi is not write protected or on a medium that is write protected.
What audio/video streams are in your avi? -
Renaming the file before I opened it up in the editor seemed to work. Thank you. As for my other thread if you at all could help that'd be great!
How to add tags to a video file in windows 7?
By Rudyard in forum ComputerReplies: 0Last Post: 8th Jan 2011, 18:29 -
Edit XMP-tags in MP3
By Fredrik_A in forum AudioReplies: 0Last Post: 4th Nov 2010, 07:54 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
abcAVI Tag Editor: Add, Browse and Change AVI tags
By devilcoelhodog in forum Newbie / General discussionsReplies: 0Last Post: 1st Mar 2009, 07:37 -
video edit program
By cunnie in forum Authoring (DVD)Replies: 1Last Post: 4th Oct 2008, 10:44
