I shot a video from Samsung S3 and I wanted to edit it on Premiere Pro.
When I played back the video, I happened to find out that it is not syncing.
I checked on the clip properties, it is shot using 29 fps.
I tried opened up the sequences for both NTSC and PAL, it does not seem syncing at all. Only NTSC is much nearer, but I do noticed the video tend to be a little bit slow.
Does anyone know how should I solve the issue?
ps. playing back from phone on comp is fine, it does not sync well on Premiere Pro.
Thread: Video and Audio Syncing
Ignore it, I managed to get it done. It had unknowingly moved the audio, and I have managed to sync it back. =)
Syncing audio to video, specific workflow
By Lowlander in forum EditingReplies: 6Last Post: 17th Jan 2013, 04:48 -
Re-syncing Audio/Video: Utility Recommendations?
By will7370 in forum Newbie / General discussionsReplies: 4Last Post: 11th May 2012, 08:24 -
Newbie here needs help syncing audio to video
By blackwaterstout in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2010, 07:19 -
Visually Syncing Audio with Video
By gonzalu in forum EditingReplies: 11Last Post: 17th Mar 2009, 19:18 -
Mini DVD's Audio/Video not syncing after being ripped
By Undead Sega in forum Camcorders (DV/HDV/AVCHD)Replies: 29Last Post: 4th Sep 2008, 16:09
