Hello
For a friend, I need to find the simplest Windows application to replace some parts of a video with PowerPoint slides. The idea is to keep the camera on the speaker and post-insert the slides mentioned in the conference.
It doesn't look like Windows Movie Maker can do that. Is there an application you could recommend from the "Video Editors (Basic)" list?
Otherwise, Sony Vegas Studio is so feature-rich that he'll probably get lost. I haven't tried others like Corel's.
Thank you.
Results 1 to 10 of 10
Hi,
Your friend needs something that is timeline-based and from what I have seen in the "Video Editors (Basic)" section, none of those programs really fit the bill. Your best bet would be, in my opinion, something from either Sony, Adobe, or Corel.
I use Premiere Pro CS6, but I have heard great things about Sony Movie Studio. I also have Corel Video Studio Pro X5. They all have their strong points, and perform the same basic functions under the hood.
There is always the option of downloading the trial versions and deciding which program is simplest to use. You may have to hunt down or type up some tutorials for your friend to do what he wants to do.
As far as replacing the video with the PowerPoint slide, all he has to do is place the slide on top of the video on the track above the track where the video resides OR cut out JUST the video portion that needs to be replaced (NOT the audio!) and replace it with the PowerPoint slide.
Brainiac -
If you have a Mac, I've heard Final Cut Pro is pretty simple and basic, and needs few skills.
You can't find a tool to do "The idea is to keep the camera on the speaker and post-insert the slides" .
But you can find all the tools do "The idea is to keep the camera on the speaker and post-insert the pictures ( bmp and/or jpeg ) "
So, screen shoot the slides, like control/Alt/PrtScn into a pictures, and pick any slide show to DVD program, and go. -
If you really want high quality, read my past posts on how to get better quality out of PPT - makes a difference!
[SOLVED] Simple tool to compress video further?
By yetanotherlogin in forum Video ConversionReplies: 16Last Post: 18th Nov 2012, 16:18 -
Insert short duration still image and save as stream copy
By supercain in forum EditingReplies: 12Last Post: 21st May 2012, 09:47 -
Looking for simple system to stream video to TV
By ovide_video in forum Media Center PC / MediaCentersReplies: 7Last Post: 21st Dec 2010, 14:08 -
How to insert slides into a video lecture?
By WoolyMammoth in forum Newbie / General discussionsReplies: 3Last Post: 28th Jun 2010, 04:28 -
Creating simple text/image to prompt 'Insert Disc 2'
By rbatty11 in forum EditingReplies: 11Last Post: 15th Feb 2009, 12:08
