    Hello everyone! I would like to have the split screen effect applied onto multicam editing mode. I can do the split screen effect when the clips are on there individual tracks. However, when multicam editing is applied, I can't do the split screen anymore because all the clips are on the same track.... Is there a way aroung this?
    Is it possible to do the split screen effect in multicam editing mode?
  2. Member Cornucopia's Avatar
    Create a 2nd track, copy the mullticam clip to the 2nd track with the same start+end (aka immediately above) change the cam choice on it to the alt desired angle, then apply the splitscreen effect.
    thanks for your response, but can you please elaborate more on how to do this...
