Does anyone possibly have directions or a tutorial on how to use Handbrake to convert a AVCHD DVD9 to MKV with no quality loss?
(Or if HandBrake can't do this conversion any other program that can is fine.)
Thank you.
Results 1 to 19 of 19
Thread: AVCHD DVD9 to MKV
You can use it for free during beta (and it's been beta forever), it's more a donation thing,...
This program seems useful. Going to give it a try.
I read somewhere that converting an ISO to MKV will take roughly as long as the moving you are converting is. This seems a bit length.
Any truth to that? -
Since MakeMKV doesn't re-encode anything, no, it will not take that long.
If you are using another program, lets say Handbrake, that will convert a dvd-video or blu ray to H264 and AAC or AC3 audio in an mkv file, then yes, the process can take much longer. But total encoding time depends on the speed of your cpu for the most part, and number of cores.
It really depends on what codecs you need for your particular playback device. Handbrake and others that use the X264 encoder will re-encode and usually produce smaller files, especially with the presets for mobile devices.
MakeMKV on the other hand, just takes the original codecs and puts them into an mkv file. So you have to know what you are starting with, and what your player needs. If your original blu ray has VC-1 video, and you use MakeMKV to go to an mkv file with it, your device may not be able to handle it. It might expect H264 in an mkv file. -
Isn't AVCHD always H264/AVC anyway? If you are running it through Handbrake, or something similar like VidCoder, there is very little reason to do so other than to compress it to a smaller size.
I really have no idea, to be honest. I keep all my stuff in MKV format and don't really know anything about AVCHD, don't use it. Only have a few movies as AVCHD which is why I want to convert them.
Your AVCHD should already have h.264 / x264 video. It also likely has AC-3 and/or DTS audio and maybe subtitles. So there should be NO NEED to re-encode if you simply want to "convert" it to a MKV file.
In other words, MakeMKV should be all you need."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
TK423 to open your original avchd/ blu ray files in makemkv click on the folder at top left and navigate to your original files, open the BDMV folder and click on the index.bdmv file located within and the file will load your bluray/avchd.
hope this helps. -
Convert MKV DVD9 to MKV DVD5
By CR88 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2011, 07:55 -
Dvd9 to mkv help
By HACKJACK in forum Newbie / General discussionsReplies: 9Last Post: 12th Mar 2011, 00:23 -
MKV to DVD9
By juicemaker in forum Video ConversionReplies: 5Last Post: 24th Dec 2009, 14:28 -
movie length into a avchd dvd9
By supersam in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Oct 2009, 00:42 -
MKV to DVD9-DL (2) discs
By ranosb in forum Video ConversionReplies: 10Last Post: 5th May 2009, 01:56
