  1. I've tried searching the forum but haven't found anything applicable: any links to other posts very welcome!
    I have a .mov file, the video plays in Quicktime 7.7.3 (1680.64) but not the audio. Movie properties shows video as H.264, the sound track has a duration and a format 'AAC', but the 'data size' shows '-NA-'.
    Vegas Movie Studio HD Platinum 11.0 only imports the audio.
    Windows Media Player plays both video and audio, so does VideoLAN / VLC Media Player (0.9.8a Grishenko), however, it does a really bad job of conversion: blocky video and no audio (this result rings a tiny bell somewhere, but I can't recall what it's about!).
    I'd really like to be able to edit this file. Any suggestions?
    I can create a small version to upload if anyone's interested.
    Started out with valve radio, crystal microphone & reel2reel tape recorder with 'magic eye' level indication...
  2. Member Cornucopia's Avatar
    First, see what an independent viewer says about this file: load it into MediaInfo and export the textmode (detailed!) output and post it here.
    BTW, nice avatar!
  3. + remuxing to mp4 might also help with compatibility
  4. Thanks for the responses! If you don't mind, I'll bear remuxing in mind for now: my previous chasing-my-own-tail muxing experiences had more in common with alchemy than anything practical.
    I downloaded MediaInfo - that's a handy gadget!
    It came out with this for the file in q.:
    General
    Complete name : E:\filepath\test.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 12.5 MiB
    Duration : 45s 31ms
    Overall bit rate : 2 329 Kbps
    Video
    Format : AVC
    Format profile : Main@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=29
    Codec ID : avc1
    Duration : 45s 31ms
    Source duration : 45s 10ms
    Bit rate : 2 247 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.891 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.245
    Stream size : 12.1 MiB (97%)
    Source stream size : 12.1 MiB (97%)
    Language : English
    mdhd_Duration : 45031
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 45s 31ms
    Source duration : 44s 443ms
    Bit rate mode : Variable
    Channel(s) : 1 channel
    Channel positions : Front: C
    Sampling rate : 22.05 KHz
    Compression mode : Lossy
    Source stream size : 234 KiB (2%)
    Language : English
    I'll be fascinated to hear an interpretation!
    Thanks again.
  5. I've just tried exporting that file using quicktime, from mov to avi. PAL-DV produced good video (but silent audio track).
    Imported that into Vegas MS, ungrouped the audio and deleted it.
    Imported the .mov into Vegas: as before, it only showed the audio channel, but the sound is there.
    So now I appear to have editable video with sound.
    It's a bit of a chore though, and I'd still be interested to know why QT can't play (or export) the sound, etc. (and why WMP and VideoLan can play both video and audio).
  6. Member Cornucopia's Avatar
    I see a couple of strange things: video framerate=29.891? Should be 29.97. Duration vs. source duration are off by 21 msec. (prob because of the framerate being non-standard). My guess is that the audio, being VBR, is throwing QT for a loop (many programs don't like VBR audio). QT usually does well with AAC-LC (but not AAC-HE). Or maybe the 1channel is "too low" for the expected QT channel layout. Audio duration vs. Source duration don't match either, this time in the opposite direction!
    I'd suggest operating on each of these separately (with tools that will work with them), and then recombining (remuxing) them later...
  7. Thanks for the detailed analysis there. The VBR observation sounds reasonable.
    This is not high-quality video (but it is significant), and the method/cludge I mentioned in my previous posting seems adequate for the purpose.
    I appreciate the help here.
