Results 1 to 9 of 9
    I am trying to convert some videos. My Archos keeps clipping off the top of these videos(it is widescreen). The trouble is is that the videos are non standard @ 480x270. Can I add some black bars to the sides so that my Archos does not crop it? Is there a better way than using black bars?
    thanks
    Does it looks stretched on your archos?
    Maybe try reconvert to some other resolution(and keep the aspect ratio/black borders) with for example xmedia recode, use the archos profiles and make a short test.
    yes it looks stretched
    thanks that looks like it will work
    I tried it with 16:9 ratio which worked.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Nice. And xmedia recode didn't crash?
    it worked on the test video only.
    I have tried every aspect ratio and the archos still crops the video. This is really frustrating.
    Does anyone know of what I can do differently that will work?
    No it didn't crash.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Sounds strange that just the test file works.
    I know.I even put it on letterbox and that did not work either.
