  1. Hi all. I have some ripped blu-rays that I need to burn to BD-Rs. They are 26-27GB and I really don't want to write them on BD-R DLs. Was wondering if there's a possibility of compressing extras only.
    Thaks.
    Use BDRebuilder:
    http://www.videohelp.com/tools/BD-Rebuilder
    You can get setup instructions on this site too. Not difficult to use and it's free. It requires a couple of other program: Avsinth 2.5, Haali Media Splitter and ffdshow. Make sure to get proper versions of these addons-not the latest version.
  3. Originally Posted by pepegot1 View Post
    Use BDRebuilder:
    I tried BD-Rebuilder but it was compessing the main movie too and I want to compress only the extras.
  4. Member hech54's Avatar
    What makes you think you can compress the "extras only" enough for all of it to fit on a single layer disc. That rarely worked for DVD....what makes you think it will work for Blu Ray?
  5. Originally Posted by hech54 View Post
    Beacause I'd calculated before trying to compress the extras.
    The main movie is 00001.m2ts - 21.1GB
    Extras:
    00025.m2ts - 557MB
    00026.m2ts - 848MB
    00027.m2ts - 1.10GB
    00028.m2ts - 578MB
    Those are the largest extras.
    pepegot1 doesn't understand what the OP asked. BDRB does NOT support only compressing the extras. Take it up with author, but don't hold your breath on this.
    Time to experiment. Since most of us around the net are trying to get rid of extras in our backups, you are flying on your own. Try deleting the main movie m2ts file and replace it with a dummy file of the same name. Then try compressing. Who knows if that will work, but worth a shot.
    Edit: BDEdit might let you do this in a more elegant manner, but its not a tool I've used.
    Or you could take the m2ts files that you want and build a new blu ray movie out of them using MultiAVCHD. Make your own menu to select each one. And compress it to fit your target disc.
  8. Originally Posted by Kerry56 View Post
    Thanks, will give it a try.
