I have Samsung 9 Series TV. Need to get HDMI signal from me PC on the first floor. The distance between TV and PC is 250 ft approx.
Also I have in-wall ethernet cable nearby the TV.
Found solutions for HDMI over CAT 6 from Atlona, and plan to buy:
transmitter:
https://www.hdwise.com/product.php?productid=2973&cat=0&page=1
and receiver:
https://www.hdwise.com/product.php?productid=2970&cat=0&page=1
This solution is also supports HDBaseT standart, means I wouldn't care about power, is it right?
And what's UR opinion of Atlona? Maybe it is better to choose another vendor?
Results 1 to 10 of 10
Sorry , I just updated the links with product description. It was something wrong with them before.
The distance between TV and PC is 250 ft250 feet is pushing it....Originally Posted by https://www.hdwise.com/product.php?productid=2973&cat=0&page=1
I believe this TV has Ethernet, why not just stream the video you want to watch via this? And not even bother with the HDMI side of things.
Or you could use an extender. Run Media Center on the HTPC and you can use an X-Box or Ceton Echo as an extender.
Well, in this case I need to buy additional device for media extender, I think it is more expensive then devices I found.
So as a solution, they recommend to check Octava solution:
https://www.hdwise.com/product.php?productid=3012&cat=0&page=1
It is supports 300ft and also 3D.
Maybe to try this solution? -
There are several free DLNA servers. A Ceton Echo is much cheaper (~US$180) than any HDMI over ethernet option -- but requires Windows Media Center running on the PC.
Losing HDMI signal to TV
By branhamr in forum Media Center PC / MediaCentersReplies: 1Last Post: 9th Apr 2011, 13:04 -
HDMI Wall Plate>>Quality?----HDMI over Cat5E/Cat6????
By cpeters12 in forum DVB / HDTVReplies: 5Last Post: 28th Jan 2011, 03:27 -
Outputting HDMI signal from laptop to TV
By Gojira in forum Software PlayingReplies: 2Last Post: 1st Jul 2009, 07:32 -
WDTV...no HDMI signal
By holmerz in forum Media Center PC / MediaCentersReplies: 1Last Post: 2nd Apr 2009, 14:19 -
HTPC, DVI to HDMI, no signal
By ToYo in forum Media Center PC / MediaCentersReplies: 19Last Post: 8th Feb 2008, 06:10
