My GPU is the Nvidia GeForce 9300 GE.
Its specs are as follows:
Dedicated video memory: 256MB DDR2
Total available graphics memory: 1535 MB
CUDA Cores: 8
Core Clock: 540 MHz
Shader Clock: 1300 MHz
Memory Data Rate: 1000 MHz
Memory interface: 64-bit
PCI Express 2.0 x16
My PC is Windows 8, 32-bit Intel Core 2 Quad Q8300 2.5GHz CPU, 3GB RAM.
My editing software runs fine but it's minimum system requirement for the GPU memory is 512MB. My GPU has 256MB memory.
Also, it requires CUDA-enabled GPU and driver 270.xx or later. GeForce GPUs: GeForce GTX 4xx Series or higher (or GeForce GT 2xx Series or higher with driver 285.62 or later)
Would it be worth the money to upgrade my GPU and buy a GPU under $50?
I also want to be able to take advantage of GPU accelerated rendering so I can render my project faster.
Thread: Upgrade GPU? Worth it?
Yes get a new one, your interface is only 64 bit. At the minimum get a 128 bit with 512MB DDR3 memory, Newegg.com is great for comparing features.
EDIT: is there a reason you chose 32 bit over Windows 8 64 bit? -
Will there be a noticeable difference in performance? I don't want to spend $30-$50 and not notice any performance increase.
Will getting a new GPU require more power? Will it generate more heat?
Yes for gaming and outputting HD video via HDMI, if $50 is all you want to spend then save up for a better PC(quad core CPU, more RAM, faster GPU, etc).
Here's a great value for an older nVidia card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500137 -
It will make a little difference if you are a serious gamer, it won't make any difference for video work.Should I get a GPU with 1GB or 512MB GPU memory?
If you encoding x264 it doesn't matter, your CPU and amount of RAM is more important for video editing and encoding.How many CUDA cores?
A little but as long as you have at least one case fan you will be OK. For $44 shipped you can't go wrong with that videocard.Will it generate more heat in my PC?
Which GPU for GPU accelerated rendering?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2013, 08:09 -
premiere 6 upgrade, section of project missing after upgrade
By krohm in forum EditingReplies: 0Last Post: 9th Jan 2013, 22:12 -
Worth it to upgrade Sony HDR-HC3?
By alegator in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 8th Jun 2012, 15:54 -
Encoders that use gpu acceleration?
By perdomot in forum Video ConversionReplies: 14Last Post: 14th Sep 2011, 10:20 -
x264 soon to be gpu accelerated?
By deadrats in forum Video ConversionReplies: 5Last Post: 12th Sep 2010, 16:52
