Results 1 to 12 of 12
  1. My BD350 will usually play MKV from the USB and show subs. Now I have one that is 1.3GB and it will nt even play movielet alone show subs. Does size of the file matter, most are around 800MB
    If the usb drive is fat32 formatted, the size limitation is 4GB
    In your case, there are other reasons for not playing (probably encoding settings, you can use mediainfo view=> text for more information)
  3. Won't play
    General
    Unique ID : 2430121145233377XXXXXXXXXXXXXXXXXXXXX (0xXXXXXXXXXXXXXXXXXXXXF3D568AB6C)
    Complete name : C:\Users\XXXXXXX\Videos\nameoffilm\nameoffilm.mkv
    Format : Matroska
    Format version : Version 2
    File size : 1.37 GiB
    Duration : 1h 31mn
    Overall bit rate : 2 135 Kbps
    Encoded date : UTC 2011-06-12 08:02:25
    Writing application : mkvmerge v4.6.0 ('Still Crazy After All These Years') ??? Mar 10 2011 02:50:32
    Writing library : libebml v1.2.0 + libmatroska v1.1.0
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Muxing mode : Header stripping
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 31mn
    Bit rate : 1 390 Kbps
    Width : 1 280 pixels
    Height : 532 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.085
    Stream size : 878 MiB (63%)
    Writing library : x264 core 114 r1924 08d04a4
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1390 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Default : Yes
    Forced : No
    Audio
    Format : DTS
    Format/Info : Digital Theater Systems
    Mode : 16
    Format settings, Endianness : Big
    Codec ID : A_DTS
    Duration : 1h 31mn
    Bit rate mode : Constant
    Bit rate : 755 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 495 MiB (35%)
    Language : English
    Default : Yes
    Forced : No
    Will play
    General
    Unique ID : 1736473130xxxxxxxxxxxxxxxxxx (0x82A34188C73A1xxxxxxxxxxxxxB1C)
    Format : Matroska
    File size : 897 MiB
    Duration : 2h 17mn
    Overall bit rate : 910 Kbps
    Encoded date : UTC 2012-05-11 09:44:55
    Writing application : mkvmerge v4.0.0 ('The Stars were mine') built on Jun 6 2010 16:18:42
    Writing library : libebml v1.0.0 + libmatroska v1.0.0
    Video
    Format : AVC
    Format profile : High@L4.0
    Format settings, ReFrames : 8 frames
    Duration : 2h 17mn
    Nominal bit rate : 873 Kbps
    Height : 692 pixels
    Display aspect ratio : 1.85:1
    Frame rate : 25.000 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.039
    Title : ==== 300mbunited.me | rpnet.biz ====
    Writing library : x264 core 120 r2120 0c7dab9
    Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=873 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : No
    Forced : No
    Audio
    Format : AAC
    Format profile : HE-AAC / LC
    Codec ID : A_AAC
    Duration : 2h 17mn
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz / 24.0 KHz
    Default : Yes
    Forced : No
    Text
    Format : UTF-8
    Codec ID : S_TEXT/UTF8
    Codec ID/Info : UTF-8 Plain Text
    Default : Yes
    Forced : No
    If anyone can tell why one will play and other won't would appreciate
    header stripping.
    Remux with the newest mkvtoolnix , or disable header compression removal in the options then remux
  5. Originally Posted by poisondeathray View Post
    header stripping.
    Many thanks What is header stripping?
    in the options where
    It causes compatibility issues with hardware players. Use search if you want more info, it's been discussed many times
    Yes in the options, file=>options=> disable header removal compression by default. I think in the newest versions v6 or newer it's off by default (there is no option available, because it's been removed), so you can just remux it without fiddling with the options
    It's an option that creates barely smaller files by removing header information. The people who designed it are morons who think that nobody will ever play files on anything but a PC because such files play fine there. It's intended to be used by financially challenged people who buy one large disk drive to hold ALL their movies and they never intend to buy another drive, so saving anything in space used, even a 1% smaller file, might be meaningful to them. I'm not exaggerating about this.
    We have another thread going on where one of our members pointed out that until recently a popular MKV muxing program turned this option on by default and made you have to work to turn it off. It caused so many problems that they no longer offer it as an option at all and it's turned off on recent releases. I remain amazed that the developers never considered that this might be a bad idea to make it on by default, but that's what happened.
  8. Originally Posted by poisondeathray View Post
    yes i was reading about that
    Thanks for your help
  9. Originally Posted by jman98 View Post
    I did think it was stupid to have one little thing removed make such a hassle
    Thanks for your help with this
    Yes you are! LOL. Savings from header removal compression are usually in the 0.1 percent range. Not a good tradeoff considering how many devices can't handle it.
  11. VH Wanderer Ai Haibara's Avatar
    It's supposedly part of the MKV spec (I never looked at it, so I wouldn't know), so Moritz (mkvtoolnix's author) was hell-bent upon enforcing it, no matter if it broke hardware player/etc. support. He was of the opinion that it'd force player manufacturers to update their players/firmware to support the 'proper' MKV spec.
    ...so, other than changing the option so that it wasn't on by default, after a while, he's recently changed his position on it?
  12. Remuxed. Works. Thanks guys
