I'm tackling a project that should be easy. I'm not a novice at DVD authoring but this has got me buffaloed.
I have Panasonic DMC-ZS7 Lumix that records video as MPEG4 (H264) 1280x720 59.94fps with audio as Dolby AC3 48000Hz stereo 192Kbps. It puts it in a .MTS file.
I want to create DVDs from these files.
I have VideoReDo Plus 3-10-3-609 (not TVSuite), Ulead DVD Movie Factory (DMF) 6.00.0004.0, Handbrake 0.9.8 (2012071700).
I realize that I need to get the .MTS transcoded to MPEG2 video with AC3 audio for the DVD. I have experimented with various settings using Handbrake but they all result in DMF showing that the file had no audio.
When trying to directly import the .MTS files into DMF, DMF says that there's a file-type mismatch.
I have tried Panasonic's PHOTOfunSTUDIO 5.0 that came with the camera. After I got around it crashing from jpegs that it didn't like in the "registered" folders, it wouldn't even display the .MTS files.
I think all I need is the necessary parameters for Handbrake to create DVD compatible MPEG2s. Could someone help me with these Handbrake parameters?
Or should I upgrade to VideoReDo TVSuite H.264?
Or is there another solution?
Thread: Panasonic MTS to DVD
Help needed with .mts avchd panasonic files
By zapster in forum Video ConversionReplies: 10Last Post: 23rd Mar 2012, 10:08 -
panasonic hdc-hs9 .MTS to .DV problem
By klein in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 27th Dec 2011, 10:43 -
Direct Stream Copy of Panasonic MTS files
By Bjerner in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 15:03 -
Panasonic HD MTS file
By Jikchung in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 11th Jul 2011, 06:52 -
Panasonic HDC-SD60 .MTS help
By BookwormSkates in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 3rd Sep 2010, 10:21
